![]() | Home > Puma (Tdci) > MAF sensor / Snorkel airflow |
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617
daft question have you checked for any obstruction in your snorkel my maf failed under hard acceleration this seems to be common
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
I'll double check it.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18053
I've never had any problems like that with mine.
Not all snorkels are created equal. Much larger pipework than most, much better under the bonnet, and no cutting required:- Click image to enlarge |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
I had a safari snorkel fitted for years and never had any problems with the MAF sensor. I run a pretty good tune as well so it sucks pretty hard, so hard that the silicone pipe i had fitted for a while used to collapse under the pressure.
Have you had it plugged in properly as the EGR can sometimes cause various misleading faults. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
I've never had a single problem with mine at all with a Safari, are you sure your MAF isn't on its way out?
EGR can sometimes affect it, with readings as well. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101
had a similar problem with mine. it ended up being the EGR. although I couldnt see much wrong with it. I changed the MAF, same fault appeared. Then changed the EGR and has been fine since
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
I also have no issues with a safari fitted > 110 XS Double Cab
I think I'll have to give that a try. Hopefully cleaning the ERG will do the trick |
| All times are GMT |
