Home > Puma (Tdci) > MAF sensor / Snorkel airflow
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
My 2010 TDCI 110 cruises with a Safari snorkle fitter cruises along at 60mph doing circa 30 MPG and 70mph doing circa 20 MPG no problem. As soon as I go up to 80mph for a more than a couple of minutes I get the good old engine light comes on and its a MAF sensor failure code (the exact one I cannot remember).
I've run it with a diagnostic app and the MAF seems to be working ok with the reading fluctuating correctly so believe it is working oK. I can clear the fault, drive at below 75mph for weeks and no fault.....
Could the fault be caused by a lack of airflow into the engine as it is being restricted by the snorkel? Has anyone experienced anything similar?
If it is the snorkel has anyone any recommendations on one I could change it for that still comes out of the side vent, I don't want to cut into the bonnet.
Post #777814 17th Jun 2019 12:21pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
daft question have you checked for any obstruction in your snorkel my maf failed under hard acceleration this seems to be common
Post #777828 17th Jun 2019 1:14pm
boxoftricks
I'll double check it.
Post #777851 17th Jun 2019 3:32pm
I've never had any problems like that with mine.
Not all snorkels are created equal. Much larger pipework than most, much better under the bonnet, and no cutting required:-
Post #777883 17th Jun 2019 6:18pm
Roy5695
I had a safari snorkel fitted for years and never had any problems with the MAF sensor. I run a pretty good tune as well so it sucks pretty hard, so hard that the silicone pipe i had fitted for a while used to collapse under the pressure.
Have you had it plugged in properly as the EGR can sometimes cause various misleading faults. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #777893 17th Jun 2019 7:04pm
I've never had a single problem with mine at all with a Safari, are you sure your MAF isn't on its way out?
EGR can sometimes affect it, with readings as well. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #777931 17th Jun 2019 10:13pm
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
had a similar problem with mine. it ended up being the EGR. although I couldnt see much wrong with it. I changed the MAF, same fault appeared. Then changed the EGR and has been fine since
Post #778104 19th Jun 2019 10:04am
hank
I also have no issues with a safari fitted > 110 XS Double Cab
Post #778106 19th Jun 2019 10:16am
boxoftricks
I think I'll have to give that a try. Hopefully cleaning the ERG will do the trick
Post #778127 19th Jun 2019 1:49pm
