|  | Home > Puma (Tdci) > MAF sensor / Snorkel airflow |
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617      | daft  question  have  you  checked  for  any obstruction   in your  snorkel   my maf failed under  hard acceleration   this  seems   to be  common | ||
|  17th Jun 2019 12:14pm |
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751      | I'll double check it. | ||
|  17th Jun 2019 2:32pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | I've never had any problems like that with mine.
 Not all snorkels are created equal. Much larger pipework than most, much better under the bonnet, and no cutting required:-   Click image to enlarge | ||
|  17th Jun 2019 5:18pm |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123      | I had a safari snorkel fitted for years and never had any problems with the MAF sensor.  I run a pretty good tune as well so it sucks pretty hard, so hard that the silicone pipe i had fitted for a while used to collapse under the pressure.
 Have you had it plugged in properly as the EGR can sometimes cause various misleading faults. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy | ||
|  17th Jun 2019 6:04pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | I've never had a single problem with mine at all with a Safari, are you sure your MAF isn't on its way out?
 EGR can sometimes affect it, with readings as well. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ | ||
|  17th Jun 2019 9:13pm |
| neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 101      | had a similar problem with mine.  it ended up being the EGR.  although I couldnt see much wrong with it. I changed the MAF,  same fault appeared. Then changed the EGR and has been fine since | ||
|  19th Jun 2019 9:04am |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | I also have no issues with a safari fitted > 110 XS Double Cab | ||
|  19th Jun 2019 9:16am |
 I think I'll have to give that a try. Hopefully cleaning the ERG will do the trick | ||
|  19th Jun 2019 12:49pm |
| Posting Rules
