Home > Maintenance & Modifications > 110 prop shaft. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
Hardy Soicer seems to be pretty reliable, I think this maybe Genuine anyway.
I have GKN UJ's on mine, I believe the two companies may have now merged unless it's my imagination. Don't forget you can run in 2WD with the diff locked if need be like I did last year, but not ideal if you have to travel far or with loads etc. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
7th Jun 2019 8:46pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Thanks Steve and yes i have had to use the diff lock when my front propshaft decided to go awol 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
7th Jun 2019 8:53pm |
A new, aftermarket rear prop from the likes of Paddocks is about £115. Give that sort of price, I'd buy and fit one of them and then refurb your existing one at your leisure. Darren
8th Jun 2019 12:00am |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1188 |
UJs with a big G clamp, big enough vice or hydraulic press are easy enough to do. Ironically the last time I had to do it I was at the other end of the county to my 80 tonne press so made do with big clamps Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
8th Jun 2019 7:36am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
If you want a replacement and/or parts, or yours reconditioned talk to bailey Morris props.
http://baileymorris.co.uk/Home Very nice helpful people. Andy. |
8th Jun 2019 7:39am |
^^^^ Anyone done their own UJ’s and then got them balanced again? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Jun 2019 1:17pm |
You shouldn't need to balance them after doing UJs. It's the prop that is balanced and provided you don't cock up the phasing of the splines in the prop itself not much to go wrong. Ed
8th Jun 2019 1:31pm |
The LR weight assembly though has a lot to be desired, I was wondering if they could be thrown of balance out over time. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Jun 2019 2:54pm |
Not on mine. It's a plate welded plenty strongly enough to the prop... The rear I can't comment on since I gave my rear prop to Retroanaconda when I swapped it for a short nose pegged Ashlocker and got a Gwyn Lewis one because of the different length. Ed
8th Jun 2019 2:59pm |
Thank you to all above 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
10th Jun 2019 9:47pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16882 |
Typical JLR quality of recent years
Click image to enlarge |
11th Jun 2019 8:17am |
I wonder what a place like Bailey Morris would charge for a prop shaft re balance? I presume they'd do that a place like that. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
11th Jun 2019 2:09pm |
