![]() | Home > Maintenance & Modifications > 110 prop shaft. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Hardy Soicer seems to be pretty reliable, I think this maybe Genuine anyway.
I have GKN UJ's on mine, I believe the two companies may have now merged unless it's my imagination. Don't forget you can run in 2WD with the diff locked if need be like I did last year, but not ideal if you have to travel far or with loads etc. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Thanks Steve and yes i have had to use the diff lock when my front propshaft decided to go awol
A new, aftermarket rear prop from the likes of Paddocks is about Β£115. Give that sort of price, I'd buy and fit one of them and then refurb your existing one at your leisure. Darren
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250 ![]() ![]() ![]() |
UJs with a big G clamp, big enough vice or hydraulic press are easy enough to do. Ironically the last time I had to do it I was at the other end of the county to my 80 tonne press
![]() 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6049 ![]() ![]() |
If you want a replacement and/or parts, or yours reconditioned talk to bailey Morris props.
http://baileymorris.co.uk/Home Very nice helpful people. Andy. |
^^^^ Anyone done their own UJβs and then got them balanced again? ____\We|Will|Win/___
You shouldn't need to balance them after doing UJs. It's the prop that is balanced and provided you don't cock up the phasing of the splines in the prop itself not much to go wrong. Ed
The LR weight assembly though has a lot to be desired, I was wondering if they could be thrown of balance out over time. ____\We|Will|Win/___
Not on mine. It's a plate welded plenty strongly enough to the prop... The rear I can't comment on since I gave my rear prop to Retroanaconda when I swapped it for a short nose pegged Ashlocker and got a Gwyn Lewis one because of the different length. Ed
Thank you to all above
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18030 ![]() ![]() ![]() |
Typical JLR quality of recent years
![]() ![]() Click image to enlarge |
I wonder what a place like Bailey Morris would charge for a prop shaft re balance? I presume they'd do that a place like that. ____\We|Will|Win/___
