Home > Puma (Tdci) > MAF issue with a '09 2.4ltr Defender Puma 110 wgn...
Page 2 of 3 <123>
Martin
Site Admin
Dead MAF in my opinion, or faulty connector/loom.
Signal coming back from it to the ECU isn't in spec so either the MAF has packed up or the connection between the MAF and the ECU is damaged.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #770161 26th Apr 2019 9:49am
X4SKP
Hello RobM
I've owned my Puma 2.4 (MY2011) for 5 years now and once a year (approximately) I get the MIL (Engine Light)
staring back at me... Not your code P0100 but P1103 (both Fuel and Air Metering / MAF identified)
So Bought a Scangauge…
Obtained the Fault Codes...
P1103
P0100
Normally after 4-6 engine cycles (Starting and Stopping) it goes away...
Then it didn't...
Thought about buying a new Sensor... Shocked
MHK501040
Genuine LR OEM £142.35 + VAT £170.82 (UK)
Claimed OEM (Interweb) £69.45 (Inc VAT)
Decided to buy some MAF Cleaner (rather than just use a low pressure air line)
so far so good 6 months no MIL (I also change my Air Filter every 6 Months)
Was also told by trusted LR independent...always check the two bulk head Earthing Points
(take apart clean each terminating eye washer and re-assemble)
I gave the Sensor a good clean...as instructed...twice and I'm hopful I get some reliable use from it,
if it fails again I'll get the LR OEM replacement...
(I can usually get 10-15% discount being a 'repeat offender' at the parts counter... Shocked)
Maybe worth a try to clean it (unless you have already)
Good Luck... SKIP
Post #770164 26th Apr 2019 10:13am
RobM
Australia 1996 Defender 110 300 Tdi SW Alaska White
Hope that's all it is and that it can be quickly solved as the time is fast approaching when we head off into the Desert... which by the way is currently closed due to flooding.... go figure Smile
Martin, what about the other 2 Not Tested ones? Are these old ones that are no longer current? Cheers.....
Rob
1995 Defender Tdi 110Wgn
1996 LR Discovery Tdi300 (A)
2009 Defender PUMA 110Wgn
My TRPS: Rob's WikiLoc Trips
Post #770166 26th Apr 2019 10:30am
RobM
X4SKP wrote:
Hello RobM
P1103
P0100
Then it didn't...
MHK501040
Good Luck...
Thanks for the reply...
When u say that it cleared itself after 5-6 starting / stopping - do u mean u had to reset it everytime until it cleared or did it just clear on its own?
Don't reckon I could be that lucky & have that work for me... Cheers.....
Rob
Post #770168 26th Apr 2019 10:34am
X4SKP
Hello RobM
For me the P01103 Fault Code has self cleared every time but one, after around 6 engine cycles...
I was set to replace the MAF Sensor but tried Cleaning it...which appears to have worked... again the MIL then self cleared
after a few more starting cycles.
Actually with my Scangauge if you try to CLEAR the P01103 Fault Code you get a 'NO RESPONCE' notice. SKIP
Post #770172 26th Apr 2019 10:50am
RobM
yeah, I had the result when trying to clear the P0100 code, but I found if I turned off the engine, then back on to accessories position only, then the SGII would clear it... not sure about the P01103 code though as I haven't had that one...
I'm assuming this P0100 (& possibly the one u mentioned above P01103) will still allow your vehicle to function/drive normally?
rob Cheers.....
Rob
Post #770174 26th Apr 2019 11:04am
X4SKP
Hello RobM
Interesting (well for us anyway... Neutral ) I'll try that, if it happens again. Don't remember exactly what I did,
but thinking about it I don't think I would have had the engine running when trying to clear the code...
so maybe I was in the condition you say worked for you.
Another piece of advice I had from the Indy' was to disconnect the battery and bring together the + and -
cables...at first thought this just feels wrong but the Battery is completely out of the equation...they do this for
LR vehicles coming in with a MIL lit up after first plugging in the various diagnostic equipment they have,
sourcing (rectifying the problem), checking the earthing points...this battery connection cable 'trick' (apparently)
can jump you to the clearing of a MIL
Good Luck... Thumbs Up SKIP
Post #770177 26th Apr 2019 11:23am
X4SKP
Hello RobM
How's yours performing now?
Have you fitted a new LR or OEM MAF Sensor?
Do you have a more 'developed' idea as to what was causing your P0100 Fault Code?
You may be able to guess at this point why I'm asking / interested... Shocked
My 6 months between...
is up... Exclamation
But this time,... for the first time, I get 'your' code
I also see on my SGII the previous MAF code 'logged'
I tried to clear these codes (having photographed them) and for me on this occasion trying to do this
with the engine running the SGII returns NO RESPONSE
Trying the Second Stage of the ignition (accessories) as you suggest, whilst the SGII take a few seconds to
come to life, it did then clear both codes without issue.
Now I know this is / can be setting up a Defender owner to think all is now ok when it may not be.
So any insight into (for you) what the problem is i'd be interested to here.
MY 2.4 tdci 90 has the original MAF Sensor fitted, 45K mileage, a new OEM Air filter every 6K, when the Engine light
come on there is absolutely no perceived difference in engine performance, or fuel 'economy'.
Thanks... SKIP
Post #775297 28th May 2019 2:19pm
RobM
Well... There's a bit of a story to my issue, which I hope and pray is now fixed..
I ended up booking the car into an independent LR mechanic to get it solved once and for all. Gave the vehicle to them for 2days & from there the vehicle was to go around to a smash repairs to have the corrosion around the alpine windows fixed. When I dropped off the car the MAF was not working all. Anyhow, a few hours later I received a call that it was just a faulty MAF sensor and they fitted a new one (Intemode brand one I believe which I could have bought myself and got it about 50% cheaper). I told them - cool and that the smash repair fella will come around and pick it up.
2 days later I went to pick the vehicle up from the smash repairer and soon as I started the engine - the Engine Check Light was back on AGAIN - Same code too.
Not a happy fella I headed straight back to the mechanics where they put their diagnostic tool on and it at first indicated that the MAF was working fine, but then all of a sudden it stopped working. He then gave some alternative reasons which were not good (possible wiring harness issue/issue with ECU). I said to the mechanic how about I pop the bonnet and wiggle some wires/connections to see what the go is... Upon lifting the bonnet and upon closer inspection of the MAF Plug, u could see some exposed copper from the wires, etc. Soon as the mechanic saw that he said it would be the plug.
2 hours of waiting the mechanic came out and said that moisture had gotten down inside the plug where the cable goes in and joins with the pins started corroding resulting in poor connection... The size of the wires to the MAF plug are very small and just weren't sealing and keeping out the moisture properly. The problem also is that apparently these plugs/pins are not a seperately sellable item so the mechanics had to source a solution and then graft this NEW plug and thicker wires into the harness AND ALL IS GOOD SO FAR...
Sorry... bit of a long story... I could just have said - Check the MAF Plug for internal corrsion to the pins/wires Rolling with laughter Cheers.....
Rob
Post #775374 28th May 2019 11:01pm
Martin
Site Admin
Glad you got it sorted, I did say it might be a loom issue Thumbs Up
Not that it helps you now, but if others are in the same situation I supply the MAF plugs: https://www.defender2.net/shop/defender-pu...s-p98.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775390 29th May 2019 8:24am
RobM
Yes, thanks Martin...
Would be nice to find out where you can buy these Pins/Plugs just in case something like this happens again... Cheers.....
Rob
Post #775395 29th May 2019 9:02am
Martin
Site Admin
You can buy them from the site shop, link in my post Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775396 29th May 2019 9:08am
RobM
Oops... Sorry Martin,
I should have spent more time in reading your post instead of glossing over it.... sorry mate Wink
I assume u just splice that plug into the wiring loom? Is the cable well sealed to prevent water ingress...? Cheers.....
Rob
Post #775406 29th May 2019 10:25am
Martin
Site Admin
No worries Laughing Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775409 29th May 2019 10:30am
X4SKP
Good to hear you have a fix RobM
Hope you kept the swapped out MAF Sensor as it looks possible it was not at fault.
I'll be taking a very close look at mine now...and if needed Martin looks to have plugged this weakness (sorry Shocked ) SKIP
Post #775428 29th May 2019 2:43pm
Page 2 of 3 <123>
