Home > My Defender > My 1984 Ninety
Page 6 of 12 <123 ... 567 ... 101112>
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
World's largest shims removed = door closes.
Reckon I could patch a chassis with those.
Door saga over, hopefully onto something more interesting next Thumbs Up Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #761470 1st Mar 2019 10:43pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Shocked
Glad you've found the problem. You can get on with enjoying it again now 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #761488 2nd Mar 2019 8:04am
L90Andy
Finally got the ultimate period correct 'factory upgrade' wheels and tyres for it now courtesy of a guy at work.
7.50 XCL's. Good enough for the launch cars, Camel Trophy and the MOD, good enough for me Cool
The contact patch is sooo narrow, more so than the XZL's. No wonder they are good in mud.
Made a great howl going along the road too Thumbs Up
Next job won't be cosmetic, will either be replace the rusted out battery box or a suspension refresh.
Thinking about the former, likely get a YRM ally box, does the whole seatbox need to come out to remove old/fit new? Instagram: L90andy
Post #763518 14th Mar 2019 9:09pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Probably, mine was out anyway so can't say for sure.
Try and remove the old one with the seat box inplace, if it works all the better.
The LRM one is good Thumbs Up 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #763742 16th Mar 2019 6:41am
L90Andy
Good call. Nothing to lose trying in situ.
Off to eBay for a spot weld drill 👍 Instagram: L90andy
Post #763785 16th Mar 2019 2:01pm
L90Andy
So I've started the battery box replacement job. You can see why I don't think Mr.MOT man would be too understanding of its condition. I'm trying to do it with the seat box in situ, I've drilled all the rivets and its basically loose now, but I'll have to get heavy handed with the grinder to actually get it out. Hoping the new aluminium one goes in relatively easily due to being in 4 pieces, but we shall see. I plan on etch priming, painting and seam sealing the new one as it goes together.
So far the hardest bit of the job was removing the old seats, they are the old style runners held in with 8x cross head screws, which were naturally all seized. Stud extractor made light work of shearing their heads off, but I've now got the captive nut plates out too so have removed the remnants of the screws ready for reassembly with the new seats.
Took the tunnel off to investigate the stuck low range mech. Something must be seized in the box so further investigation required.
Also I initially thought the difflock mech worked because the lever moved freely, however now I can see there is loads of movement at the pivot bush on the side of the tbox so its not actuating the difflock itself. Perhaps that's seized too and forcing the lever has worn the pivot bushes out?
Still, its not all bad as found 20p behind the seats Rolling with laughter
Any advice on any of the above gratefully received! Instagram: L90andy
Post #769081 18th Apr 2019 9:43am
Those XCL's are sweet. I used to run them all the time (although I *ahem* had a source for them)
Can't beat a basic classic looking 90/110 with 7.50s
You just need an 8274 or a Husky to finish it off.
Post #769154 18th Apr 2019 9:30pm
L90Andy
Looks like we're of the same mind Jim Cool
There are a couple of bits lurking under the work bench that are headed for this, tune in for future updates! Instagram: L90andy
Post #769177 19th Apr 2019 9:36am
L90Andy
Four days holiday and I only managed twenty minutes on it!
Still, with the aid of the angle grinder out came the battery box Smile
Bit of a clean up, then prep of the new bits and we'll be onto reassembly.
 Instagram: L90andy
Post #769771 23rd Apr 2019 8:02pm
Procta
I have a badge for this if your interested ? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #769818 24th Apr 2019 4:51am
L90Andy
Hi Procta. Think I'm ok for badges thanks, but out of interest which one are you talking about? Instagram: L90andy
Post #769994 25th Apr 2019 11:07am
L90Andy
Whilst waiting for more prep supplies to arrive I've started to investigate the stuck low range mechanism.
Got the top housing off, two of the bolts badly corroded, the other four nearly new looking.
Not surprised to find the shaft seized in the housing. I'll drift it out, clean and lube it then replace the o-ring and refit.
Then onto the diff lock which is also seized! Big Cry
 Instagram: L90andy
Post #769998 25th Apr 2019 11:15am
L90Andy
Before putting the new battery box in I took the opportunity to flap disk the chassis back and get some CIO all over it. Mmm shiney.
Check out the amount of filth that's come off the car just from this job!
Meanwhile I dry assembled the new box just to check it out. Also keyed the surfaces so the paint might last more than one drive.
Then etch primed and painted it.
Reassembly next 😁 Instagram: L90andy
Post #770593 28th Apr 2019 9:09pm
Procta
the one for the grill Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #770686 29th Apr 2019 2:40pm
L90Andy
Ah, they didn't have them there on these early ones. Thanks for the thought though Thumbs Up Instagram: L90andy
Post #770698 29th Apr 2019 3:28pm
