Home > Maintenance & Modifications > Best place to start sound proofing?
Co1
I can’t afford to crackers and do the lot in 1 lump, so where is the best place to start to quieten down the cab? It’s a 90 HT.
Col
Post #769556 22nd Apr 2019 8:51am
Rear wheel boxes and hard top sides. After that, I'd remove the heading and do the roof. Does yours have a headlining in the rear? If not, then adding one is a worthwhile exercise, too.
Something like this (pictures taken of the rear of my 110USW and my old 90 roof):
Apart from the instant improvements, they're also the easiest to do, being largely square flat panels.
There will also be improvements to be made from doing the seat box, floor and doors but these are more difficult and time consuming due to the shapes and the need to strip out things like the seats and trim. Darren
Post #769562 22nd Apr 2019 9:19am
Roverdude
United Arab Emirates 2014 Defender 90 Puma 2.2 SW Tamar Blue
Concur. Start with the back and move your way forward. I dynamatted the entire interior of my 2014 D90 SW and the most noticeable improvement was when I did the rear. The front was a marked improvement too, but if I had to start with one I'd do the rear first.
Post #769565 22nd Apr 2019 9:31am
Co1
Nice one. Thanks.
Post #769567 22nd Apr 2019 9:36am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
interested in people’s thoughts as I am thinking the same. Did my last one in one go and not again. Problem I have slightly is I want to keep the inside looking stock so bare wheelarches etc.
Been looking at these eBay eBay Item No. 371565861360 as can do a section at a time
Post #769632 22nd Apr 2019 7:52pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Lucky for me when i did the foot wells i did not stick the sound proofing onto the floor but just put it under the rubber mats as when water has come in from having rubbish aftermarket door seals i could just take them out and thoroughly dry the bare floor with a towel. Cannot wait for the new LR original seals to arrive and then fit
Post #769638 22nd Apr 2019 8:24pm
The pre-cut kits are a very expensive way to do it, particularly when cutting regular sheets is so easy to do. Also, SilentCoat is slightly cheaper than Dynamat and they both do the same thing. Darren
Post #769647 22nd Apr 2019 8:52pm
Sphere
I do agree however good way to spread the cost as a bulk pack of dynamat is quite expensive.
Post #769655 22nd Apr 2019 9:17pm
kaney
I bought this off Amazon worked a treat simlar products at Amazon if none left
Mayuber 10sqm Aluminium Foil Insulation Liner for Van Car Vehicle Thermal Soundproof Foam 1m x 10m
Post #769658 22nd Apr 2019 9:35pm
You can buy a 30 sheet pack of Silent Coat for £34, which is more than enough for the footwells.
https://www.ebay.co.uk/itm/Silent-Coat-2mm...Swqu9VLm0D Darren
Post #769661 22nd Apr 2019 9:56pm
Co1
The silent treatment!
Bought the silent coat bumper pack and did the tub, sides and roof in the back of the 90. Enjoyable few hours and an impressive result.
Post #770377 27th Apr 2019 1:39pm
Sulisuli
Nice work, soundproofing is very satisfying Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #770393 27th Apr 2019 6:09pm
markb110
Anyone else remember seeing people drive Lightweights wearing ear defenders. Guess you cant get easier and cheaper than that....
Post #770395 27th Apr 2019 6:42pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Just finished the Silent Coat. Went for 4mm. Now overlaying with 5mm closed cell water proof foam. The silent coat is real easy to cut. I templates a few bits with card first. Don’t recommend pre cut stuff as tends to be a poor fit.
Post #770423 27th Apr 2019 9:26pm
boxoftricks
Had the same thought but the wheel arches are really noisy.
Post #770424 27th Apr 2019 9:28pm
