![]() | Home > Maintenance & Modifications > Best place to start sound proofing? |
Rear wheel boxes and hard top sides. After that, I'd remove the heading and do the roof. Does yours have a headlining in the rear? If not, then adding one is a worthwhile exercise, too.
Something like this (pictures taken of the rear of my 110USW and my old 90 roof): ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Apart from the instant improvements, they're also the easiest to do, being largely square flat panels. There will also be improvements to be made from doing the seat box, floor and doors but these are more difficult and time consuming due to the shapes and the need to strip out things like the seats and trim. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Roverdude Member Since: 27 Jan 2019 Location: Abu Dhabi Posts: 11 ![]() ![]() ![]() |
Concur. Start with the back and move your way forward. I dynamatted the entire interior of my 2014 D90 SW and the most noticeable improvement was when I did the rear. The front was a marked improvement too, but if I had to start with one I'd do the rear first.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784 ![]() ![]() ![]() |
Nice one. Thanks.
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
interested in people’s thoughts as I am thinking the same. Did my last one in one go and not again. Problem I have slightly is I want to keep the inside looking stock so bare wheelarches etc.
Been looking at these eBay eBay Item No. 371565861360 as can do a section at a time |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Lucky for me when i did the foot wells i did not stick the sound proofing onto the floor but just put it under the rubber mats as when water has come in from having rubbish aftermarket door seals i could just take them out and thoroughly dry the bare floor with a towel. Cannot wait for the new LR original seals to arrive and then fit
The pre-cut kits are a very expensive way to do it, particularly when cutting regular sheets is so easy to do. Also, SilentCoat is slightly cheaper than Dynamat and they both do the same thing. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I do agree however good way to spread the cost as a bulk pack of dynamat is quite expensive.
I bought this off Amazon worked a treat simlar products at Amazon if none left
Mayuber 10sqm Aluminium Foil Insulation Liner for Van Car Vehicle Thermal Soundproof Foam 1m x 10m |
You can buy a 30 sheet pack of Silent Coat for £34, which is more than enough for the footwells.
https://www.ebay.co.uk/itm/Silent-Coat-2mm...Swqu9VLm0D Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The silent treatment!
![]() Click image to enlarge Bought the silent coat bumper pack and did the tub, sides and roof in the back of the 90. Enjoyable few hours and an impressive result. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808 ![]() ![]() ![]() |
Nice work, soundproofing is very satisfying
![]() 2008 SVX 90 2000 XS TD5 90 |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Anyone else remember seeing people drive Lightweights wearing ear defenders. Guess you cant get easier and cheaper than that....
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
![]() Click image to enlarge Just finished the Silent Coat. Went for 4mm. Now overlaying with 5mm closed cell water proof foam. The silent coat is real easy to cut. I templates a few bits with card first. Don’t recommend pre cut stuff as tends to be a poor fit. |
Had the same thought but the wheel arches are really noisy. |
