Home > Technical > defender 90 engine failure at 25k !!
Page 1 of 3 123>
kevinz3
2007 Defender 90 Puma 2.4 HT Epsom Green
hi all
just thought i would share , engine gave very loud clattering so stopped and towed to main dealer, told me today engine failure and £5700, been on to land rover to see what they will do , i have to pay for engine strip myself to see what caused it, then they might contribute, what a joke anyone have any tips on how to get redress from land rover, its a may 2007 registered
thanks kevin
Post #76852 20th Jun 2011 5:57pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
So no clue to engine failure, oil intact, any codes, did it smoke first, MIL light come on, it must have just been serviced judging by the mileage. We are interested to find out as it seems rareish, haven't been many reports of total engine failure. Been a few but then again we don't get reports of non failure.
Oh Hello by the way. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #76860 20th Jun 2011 6:47pm
willy eckerslike
Cheap engine here won't cost much to fit
http://cgi.ebay.co.uk/DEFENDER-2-4-TDCI-EN...5adef2b0cc Original Member Pie n Pea Club.
110 HCPU Tipper
Post #76861 20th Jun 2011 6:51pm
kevinz3
hi
no warning at all , not a light on the dash just heading down the motorway then major clatter, getting stripped down in the morning to see what caused the problem so i hope they will come with some help toward the cost
Post #76875 20th Jun 2011 8:38pm
Zagato
Nice to know you can get hold of them for that price.
I know of one that blew up at 60,000 miles on an 09 model. The owner repeatedly complained from the outset that it sounded rough but they wouldn't do anything about it. Luckily he does 80,000 a year hard towing so it blue up within the first year of warranty and they put in a new one which has been fine and now on 160,000 Thumbs Up The reason he chose a TDCi apart from loving Defenders is that they were the only company that offered a 3 year unlimited mileage warranty (used to use a TD5 which did 250,000 hard towing and was still going strong when he traded up!)
If it's been serviced correctly surely they should replace the engine for you Rolling Eyes
Post #76880 20th Jun 2011 9:34pm
noworries4x4
Mine died at 26thou when stripped they found the oil pump relief valve had jammed and pumped every thing full of oil, engine hydraulic locked big clatter stopped dead on the A303 very early one morning. But i was fully under warrenty no issues apart from the time it took them to sort, Enterprise had me in a Censored Transit for 4 weeks.
Over 175thou heavy towing all the time and still going strong. Transmission is getting a bit slack now but to be expected. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #76905 20th Jun 2011 11:18pm
noworries4x4
80thou a year i thought i was always at the wheel doing 50thou a year but my TD5 before this did not do very well at all W reg constant head and head gasket problems, constant hi speed towing killed it. The 6 speed box of the Puma is what saves the engine i think, also the speed limiter helps stops me thrashing it for hours on end on the motorway. If everything is under control you are not going fast enough.
No Worries 4X4
Post #76908 20th Jun 2011 11:25pm
dgardel
Italy
Re: defender 90 engine failure at 25k !!
kevinz3 wrote:
hi all
thanks kevin
How many kms or miles? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #76911 21st Jun 2011 12:30am
LR90XS2011
There are often engines comming up on ebay there is an engine/box and bulkead complete on there now, also some specialists have them, I think JE engineering had a few new ones from V6 conversions they were doing. still a big hole in anyones pocket though. DEFENDER 90 TDCI XS,
Post #76916 21st Jun 2011 6:27am
Zagato
dgardel wrote:
kevinz3 wrote:
hi all
thanks kevin
A clue is in the title 25K - will be miles Thumbs Up
Post #76920 21st Jun 2011 7:20am
dgardel
Italy
ehmmm, I saw now Embarassed
Thanks Zag Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #76925 21st Jun 2011 7:50am
BigMike
Daniele, just because you have smart seats doesn't mean you are clever Laughing Wink
Post #76930 21st Jun 2011 8:16am
Naks
Friend of mine in Namibia also thought his engine had gone bang - the noise was so bad when it happened that he thought it had thrown a piston or 2!
When they stripped the engine he convinced LR Windhoek to test the injectors and it turned out all 4 had failed, rest of the engine was fine.
Could be a possibility? --
Post #76932 21st Jun 2011 8:20am
dgardel
Italy
Evil or Very Mad
You are wrong!!!!
see my photo!!!
IID Pro MV License
Post #77080 21st Jun 2011 10:58pm
kevinz3
update on the landy is they still have to strip the engine to find fault land rover will contribute if its a non serviceable part that caused the failure so hope its good news for me when they strip it down
Post #77170 22nd Jun 2011 8:07pm
Page 1 of 3 123>
