Home > Technical > defender 90 engine failure at 25k !!
Page 2 of 3 <123>
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Has it got full main dealer service history? If yes then even
If it's a serviceable part , it's down to them!
Anyhow not sure what serviceable part failure would cause
A 25k engine to self destruct:-@
Look forward to the answer. As I'm looking to replace my
300 tdi with a tdci:-/ Have fun be happy
Post #77374 23rd Jun 2011 6:00pm
BigMike
what he said. if its a serviceable part and its been serviced correctly with OEM parts then its their problem. they cant wriggle out of that one I'm afraid (assuming you didnt wade upto the bonnet and hydraulic the engine)
Post #77408 23rd Jun 2011 7:29pm
kevinz3
2007 Defender 90 Puma 2.4 HT Epsom Green
hi guys, just had the dealer on thr blower and she said after strip down the shells have gone and crankshaft disintegrated, cause she said unknown and she contacting land rover, and ideas or opinions on what i should expect from them
Post #77587 24th Jun 2011 5:30pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I had a TD5 engine go at 97,000 miles on a Disco 2 10 days out of warranty. Land Rover initially offered 50% eventually got them up to 75% plus dealer fitted new clutch at cost at same time. Bill would have been around £7.5K. Be polite but persistent with dealer.
Post #77588 24th Jun 2011 5:38pm
Tompoole
Always be polite the person you deal with isn't responsible
For the engine giving out. But if it has ful Landrover history
Insist on engine replacement at thief cost , make very complaint
In writing, follow up every phone conversation with a letter
Be calm but firm . If it has full landrover history , they will
Cough up eventually. Normally they send engine back to the
Person that assembled it to be rebuilt. Have fun be happy
Post #77590 24th Jun 2011 5:48pm
dgardel
Italy
What kind of engine oils was used? dealer oil? others types? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #77673 24th Jun 2011 11:45pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
willy eckerslike wrote:
Cheap engine here won't cost much to fit
http://cgi.ebay.co.uk/DEFENDER-2-4-TDCI-EN...5adef2b0cc
A bit off topic - but damn - I paid more for having my 4 injectors changed on a engine with 47.000 on the clock....ebay next time.
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #77685 25th Jun 2011 7:26am
Tompoole
CRJ[/quote]
Shocked Shocked Shocked Shocked Shocked Have fun be happy
Post #77815 25th Jun 2011 8:57pm
kevinz3
update today
dealer called , engine shells and crankshaft in bit , no known cause she said , mechanic said impossible to tell, i think we were a little overdue for a service but only a few months , but its only done 7k since last service, land rover have escalated the claim to a senior manager so waiting to see what they say
Post #78043 27th Jun 2011 3:43pm
dgardel
Italy
kevinz3 wrote:
update today
IID Pro MV License
Post #78054 27th Jun 2011 4:48pm
MK
....and you can probably save some oil to run a test Puma 110" SW
Post #78066 27th Jun 2011 7:02pm
kevinz3
all main dealer oil as it was only done at 18k and packed in at 25k so god knows whats went wrong , as it never used any oil between service
Post #78081 27th Jun 2011 8:05pm
kevinz3
call from land rover today they will not contribute anything at all to cost as its out of warranty and they said although they sympathise they are no obliged to , so much for them then
Post #78987 4th Jul 2011 6:50pm
MK
Wow! Did they diagnosed WTH went wrong? Did they give you any pics? reports? Puma 110" SW
Post #79000 4th Jul 2011 8:03pm
CGAUER
Brazil 2005 Defender 110 300 Tdi SW Epsom Green
kevinz3,
same issue with a friend here in Brazil. Engine packed at just 35k Km.. Exact the same broken bits + the way it happened. LR covered it. So far they've replaced (over the same 110):
Gearbox
2x Clutch + cover
2x master + slave clutch cylinders
ABS/TC ECU
Turbo
Exhaust manifold
EGR valve
Vacuum pump
Its a y2009 Puma. 236 days parcket at LR workshop due to the faults above and because they crashed the landie and also bent the wings during the engine swap at LR finest.
We established the 300TDI as "the" Land Rover for our conditions. The Pumas and TD5s just can't take our dirty Diesel and humidity + constant wadings and lack of LR support over certain places. We had the 300TDI until 2006, with TD5 interior and dash. The later 300TDI engine was made in Brazil by International Harvester / MWM. Bit stronger, new turbo and Euro II, but a LOT noisier than the early 300TDIs.
Take a look at LR's service and technical bulletins. There is a lot of trouble going on regarding early versions of the TDCI. Probably you could manage to replace yours at no cost, after some arguing.
LR's technical reference site:
topix.landrover.jlrext.com/ Land Rover Defender 110 SW 300tdi 2005
Suzuki Jimny 1.3 VVT 2010
www.cgauer.com.br
www.vimeo.com/25710554
www.flickr.com/cgauer/sets
Post #79646 9th Jul 2011 8:07pm
Page 2 of 3 <123>
