![]() | Home > Technical > defender 90 engine failure at 25k !! |
what he said. if its a serviceable part and its been serviced correctly with OEM parts then its their problem. they cant wriggle out of that one I'm afraid (assuming you didnt wade upto the bonnet and hydraulic the engine)
kevinz3 Member Since: 20 Jun 2011 Location: dumfriesshire Posts: 7 ![]() ![]() |
hi guys, just had the dealer on thr blower and she said after strip down the shells have gone and crankshaft disintegrated, cause she said unknown and she contacting land rover, and ideas or opinions on what i should expect from them
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
I had a TD5 engine go at 97,000 miles on a Disco 2 10 days out of warranty. Land Rover initially offered 50% eventually got them up to 75% plus dealer fitted new clutch at cost at same time. Bill would have been around £7.5K. Be polite but persistent with dealer.
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 830 ![]() ![]() ![]() |
Always be polite the person you deal with isn't responsible
For the engine giving out. But if it has ful Landrover history Insist on engine replacement at thief cost , make very complaint In writing, follow up every phone conversation with a letter Be calm but firm . If it has full landrover history , they will Cough up eventually. Normally they send engine back to the Person that assembled it to be rebuilt. Have fun be happy |
What kind of engine oils was used? dealer oil? others types? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
A bit off topic - but damn - I paid more for having my 4 injectors changed on a engine with 47.000 on the clock....ebay next time. CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
CRJ[/quote] ![]() ![]() ![]() ![]() ![]() |
update today
dealer called , engine shells and crankshaft in bit , no known cause she said , mechanic said impossible to tell, i think we were a little overdue for a service but only a few months , but its only done 7k since last service, land rover have escalated the claim to a senior manager so waiting to see what they say |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
....and you can probably save some oil to run a test Puma 110" SW
all main dealer oil as it was only done at 18k and packed in at 25k so god knows whats went wrong , as it never used any oil between service
call from land rover today they will not contribute anything at all to cost as its out of warranty and they said although they sympathise they are no obliged to , so much for them then
Wow! Did they diagnosed WTH went wrong? Did they give you any pics? reports? Puma 110" SW
CGAUER Member Since: 09 Jul 2011 Location: São Paulo Posts: 3 ![]() ![]() ![]() |
kevinz3,
same issue with a friend here in Brazil. Engine packed at just 35k Km.. Exact the same broken bits + the way it happened. LR covered it. So far they've replaced (over the same 110): Gearbox 2x Clutch + cover 2x master + slave clutch cylinders ABS/TC ECU Turbo Exhaust manifold EGR valve Vacuum pump Its a y2009 Puma. 236 days parcket at LR workshop due to the faults above and because they crashed the landie and also bent the wings during the engine swap at LR finest. We established the 300TDI as "the" Land Rover for our conditions. The Pumas and TD5s just can't take our dirty Diesel and humidity + constant wadings and lack of LR support over certain places. We had the 300TDI until 2006, with TD5 interior and dash. The later 300TDI engine was made in Brazil by International Harvester / MWM. Bit stronger, new turbo and Euro II, but a LOT noisier than the early 300TDIs. Take a look at LR's service and technical bulletins. There is a lot of trouble going on regarding early versions of the TDCI. Probably you could manage to replace yours at no cost, after some arguing. LR's technical reference site: topix.landrover.jlrext.com/ Land Rover Defender 110 SW 300tdi 2005 Suzuki Jimny 1.3 VVT 2010 www.cgauer.com.br www.vimeo.com/25710554 www.flickr.com/cgauer/sets |
