![]() | Home > Technical > defender 90 engine failure at 25k !! |
So no clue to engine failure, oil intact, any codes, did it smoke first, MIL light come on, it must have just been serviced judging by the mileage. We are interested to find out as it seems rareish, haven't been many reports of total engine failure. Been a few but then again we don't get reports of non failure.
Oh Hello by the way. Original Member Pie n Pea Club. 110 HCPU Tipper |
Cheap engine here won't cost much to fit
http://cgi.ebay.co.uk/DEFENDER-2-4-TDCI-EN...5adef2b0cc Original Member Pie n Pea Club. 110 HCPU Tipper |
kevinz3 Member Since: 20 Jun 2011 Location: dumfriesshire Posts: 7 ![]() ![]() |
hi
no warning at all , not a light on the dash just heading down the motorway then major clatter, getting stripped down in the morning to see what caused the problem so i hope they will come with some help toward the cost |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Nice to know you can get hold of them for that price. I know of one that blew up at 60,000 miles on an 09 model. The owner repeatedly complained from the outset that it sounded rough but they wouldn't do anything about it. Luckily he does 80,000 a year hard towing so it blue up within the first year of warranty and they put in a new one which has been fine and now on 160,000 ![]() If it's been serviced correctly surely they should replace the engine for you ![]() |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Mine died at 26thou when stripped they found the oil pump relief valve had jammed and pumped every thing full of oil, engine hydraulic locked big clatter stopped dead on the A303 very early one morning. But i was fully under warrenty no issues apart from the time it took them to sort, Enterprise had me in a
![]() Over 175thou heavy towing all the time and still going strong. Transmission is getting a bit slack now but to be expected. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
80thou a year i thought i was always at the wheel doing 50thou a year but my TD5 before this did not do very well at all W reg constant head and head gasket problems, constant hi speed towing killed it. The 6 speed box of the Puma is what saves the engine i think, also the speed limiter helps stops me thrashing it for hours on end on the motorway. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
How many kms or miles? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
There are often engines comming up on ebay there is an engine/box and bulkead complete on there now, also some specialists have them, I think JE engineering had a few new ones from V6 conversions they were doing. still a big hole in anyones pocket though. DEFENDER 90 TDCI XS,
A clue is in the title 25K - will be miles ![]() |
ehmmm, I saw now
![]() Thanks Zag Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Daniele, just because you have smart seats doesn't mean you are clever
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
Friend of mine in Namibia also thought his engine had gone bang - the noise was so bad when it happened that he thought it had thrown a piston or 2!
When they stripped the engine he convinced LR Windhoek to test the injectors and it turned out all 4 had failed, rest of the engine was fine. Could be a possibility? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
![]() You are wrong!!!! see my photo!!! ![]() ![]() IID Pro MV License |
update on the landy is they still have to strip the engine to find fault land rover will contribute if its a non serviceable part that caused the failure so hope its good news for me when they strip it down
