![]() | Home > Puma (Tdci) > Anti Stall |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
Anti stall is just an electronic governor, if the load exceeds the max torque the engine can make it will still stall, less likely in first and very unlikely in low range first and reverse where idle jack also kicks in. DEFENDER 90 TDCI XS,
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Yes it will except for 1st and reverse in high and the same on low range. It would be because you were in 2nd low range.
Safety plays a part I would imagine too hence this being the case. In low gears it’s a great feature, I use it all the time. Even in those lowest gears it will not cut out transversing most terrain but if it hit an object it would do. Again, I’m pretty sure this was tested in the past and is a safety feature. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Remember also that if you have any throttle input the anti-stall will disengage, so touching the accelerator can make it stall.
Anti-stall is only active when your foot is completely off the pedal. |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
I should add:
1. Was 2nd gear high range. 2. It was up a hill. Thanks M |
In that case you were probably demanding more torque than the engine can provide at tickover.
I also thought a Puma would never stall in 1st. I never stalled it in 10 years, and that includes starting from standstill on pretty steep uphill stretches in 1st high without touching the gas pedal. Until my daughter as a student driver once managed to stall it on flat grass land in our garden. Myth busted. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
If you bring up the clutch like lightning it will.
![]() ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
A foot slipping suddenely off the clutch will cause it to stall in 1st, especially when you're hanging out the door holding onto a lamb...
Don't ask. ![]() |
Interesting. The restrictor in the clutch hydraulic line is supposed to prevent that.
