Home > Puma (Tdci) > Anti Stall
Markez79
Anti Stall
This may be a stupid question....but can the defender still stall when it has ‘anti stall’ in 1st and 2nd gear?!
The reason I ask is that I was in a wet grass field today and going along in second relying on the anti stall rather than the accelerator....and it stalled!
Thanks
M
Post #768838 16th Apr 2019 5:27pm
LR90XS2011
Anti stall is just an electronic governor, if the load exceeds the max torque the engine can make it will still stall, less likely in first and very unlikely in low range first and reverse where idle jack also kicks in. DEFENDER 90 TDCI XS,
Post #768839 16th Apr 2019 5:31pm
Yes it will except for 1st and reverse in high and the same on low range. It would be because you were in 2nd low range.
Safety plays a part I would imagine too hence this being the case.
In low gears it’s a great feature, I use it all the time.
Even in those lowest gears it will not cut out transversing most terrain but if it hit an object it would do.
Again, I’m pretty sure this was tested in the past and is a safety feature. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #768842 16th Apr 2019 5:43pm
Remember also that if you have any throttle input the anti-stall will disengage, so touching the accelerator can make it stall.
Anti-stall is only active when your foot is completely off the pedal.
Post #768846 16th Apr 2019 5:59pm
Markez79
I should add:
1. Was 2nd gear high range.
2. It was up a hill.
Thanks
M
Post #768850 16th Apr 2019 6:25pm
In that case you were probably demanding more torque than the engine can provide at tickover.
Post #768853 16th Apr 2019 6:30pm
ericvv
Re: Anti Stall
Thanks
M
I also thought a Puma would never stall in 1st. I never stalled it in 10 years, and that includes starting from standstill on pretty steep uphill stretches in 1st high without touching the gas pedal. Until my daughter as a student driver once managed to stall it on flat grass land in our garden. Myth busted. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #768859 16th Apr 2019 7:07pm
If you bring up the clutch like lightning it will. Laughing I've only ever done that once. Whistle Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #768867 16th Apr 2019 7:51pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
A foot slipping suddenely off the clutch will cause it to stall in 1st, especially when you're hanging out the door holding onto a lamb...
Don't ask.
Embarassed
Post #768903 17th Apr 2019 3:59am
Interesting. The restrictor in the clutch hydraulic line is supposed to prevent that.
Post #768921 17th Apr 2019 8:21am
