![]() | Home > Technical > Key fob replacement **please answer quick if poss** |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
I change my battery without reprogramming anything.
Just do it at quite a distance from the Landy so the fob isn’t in range of the alarm unit. And change it as quick as possible Instagram - @r22oyp Roy |
If you don’t often use the key in the lock they can become seized. You can get lock grease that can prevent this happening. Unless somebody has changed the door handle/lock. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3898
Thanks 👍
| All times are GMT |
