Home > Technical > Key fob replacement **please answer quick if poss**
Stacey007
Hello
Away from home and locked car , could not get in pressing remote for ages, guess battery dead?
Can I replace battery without having anything reprogrammed?
Also Key didn't seem to fit in lock (door lock) should it?
Thanks
Post #766195 31st Mar 2019 8:33am
Roy5695
I change my battery without reprogramming anything.
Just do it at quite a distance from the Landy so the fob isn’t in range of the alarm unit. And change it as quick as possible Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #766196 31st Mar 2019 8:40am
Roy5695
If you don’t often use the key in the lock they can become seized. You can get lock grease that can prevent this happening. Unless somebody has changed the door handle/lock. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #766198 31st Mar 2019 8:42am
Stacey007
Thanks 👍
Post #766199 31st Mar 2019 8:45am
