Passenger side front electric window did not work anymore. Not the fuse, not a snapped cable. So took it to the dealer this morning, just heard it is the electric motor itself that malfunctions. With some tapping they could get it to work again briefly, but that did not last. Cause is moisture, probably condensation. Nothing wrong with the inside of the door panel or frame. That is all fully Dinitrolled. New motor ordered, which will arrive at 2 PM with the second parts tour, so truck will be ready for pick up still tonight.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Busy days a head for you Clayton, will it have a thatched roof
![]() 2008 SVX 90 2000 XS TD5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
Don't mind this type of busy work, especially for my shed / mancave
![]() No thatched roof on this ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Avoided work. Gave the girl a wash in the sunshine.... and then took a lot of photos
![]() ![]() Click image to enlarge |
Only one, where's the rest of the photo's ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 ![]() ![]() |
I drove to the shop, clutch died
![]() Now got to find someone to recover and fix, clutchfix kit and achcroft output shaft ordered ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
A pigeon met its maker.
The thud at 60mph woke up Mrs Greeni (yes the v8 burble is THAT soothing)! I didn't even slow down... Feathers came in as the sides were rolled up (standard position). ![]() Click image to enlarge As I used to fit screens for a living, the glass was out within 4 minutes from getting home. No, I'm not going fit a heated one ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
^^^^ Bloody hell. They do often try to dive bomb you.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I find it's easier to just shoot them... ![]() |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
![]() Click image to enlarge Wash and clean and polish ....never going to be a smart example but she is mine .. |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 333 ![]() ![]() ![]() |
Well I finally had a minute spare so picked two of the easiest jobs to do.
1. Fitted 2 new brake pedal return springs 2. Adjusted the handbrake What a faf both were to complete, especially the springs. Lets hope neither need doing again soon. |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3630 ![]() ![]() ![]() |
Went to see my Mother-in-Law. Aparently it was Mothering Sunday. No one had told me
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
Had a quick look under the 90 and found a few jobs for springtime.
Err new bump stops ![]() Click image to enlarge And new trailing arm bushes too! ![]() Click image to enlarge 2002 td5 90 county hardtop |
Busy week for the two Defenders, both serviced, new tyres on mine (BFG 265/75R/16 KO2) tyres from mine which were (BFG 265/75R/16 KO2) onto SWMBO (she is delighted) made it look more purposeful with the wheel spacers was her description
![]() Clutch spring fitted, what a difference that has made ![]() Warranty works including replacing both leaking rear diff seals and steering box seal Water ingress in 3 places rectified. Glad to have the Defender back so I can drive it and enjoy it after having fitted the Optimill front hinges, replacement chequerplate and new cubby box 24 hrs before taking it in for the above works to be done. The automatic loan cars I had, Evoque and Discovery sport are very easy to drive but don’t have the character of a Defender ![]() 2008 SVX 90 2000 XS TD5 90 |
