Home > Td5 > Land Rover defender td5 skidding when hard acceleration
Page 2 of 2 <12
Defender Fun
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hello
I have had a look this evening and cant seem to find any leak (unfortunately) so i think it will need a new clutch, i have got two 4x4 land rover specialists based near me, however i know they will be expensive for the clutch replacement £700 plus, (£800 for my Puma defender two years ago). i have had a look online and have a preliminary quote from MR clutch for £450. has anyone used this firm or any other reasonable firms you can recommend?
Kind Regards
Post #756862 6th Feb 2019 9:34pm
landy andy
Don’t go cheap. You need someone who knows, and cares about Defenders. We all know they ain’t normal
Post #756879 6th Feb 2019 10:08pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
For the actual parts use Valeo only it is OEM and a lot cheaper than genuine green oval boxed parts. Don’t use anything else. Alternatively you could us custom clutch manufacturers like you guys have other there. They seem to be popular and decent enough but my experience with Valeo is excellent.
Good luck. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #756921 6th Feb 2019 11:33pm
jst
Have you tested the clutch against the handbrake?
Any smells? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #756951 7th Feb 2019 8:37am
geobloke
I have just had this problem with Miffy.
Best way to describe it is in forth gear when accelerating up a relatively steep slip-road She will accelerate then at peak torque the engine would begin to rev like an automatic gearbox kicking down a gear, meanwhile the vehicle is slowing down, then by babying the accelerator she would get back up to speed.
The cause: Faulty clutch release bearing that ate away the pressure plate springs. No I do not ride the clutch pedal... This is a two year old clutch... Not impressed with Valeo or LR's HD release bearing. Thankfully no damage to the flywheel.
This time I have up'd the ante and bought an LOF clutch and this weekend I have just reached the bedding-in mile mark... Twisted Evil Twisted Evil Honestly it has been a real challenge not to try out the uprated performance clutch and plant the loud pedal. Early signs are good, very very goooooodddddddd Mr. Green Mr. Green Mr. Green
Post #757348 8th Feb 2019 6:00pm
Defender Fun
Hi
Thank you for your reply’s, sorry to my late update. After further investigation I have found it is the fuel pressure components leaking. Just need to get a repair kit now
Thank you for your help
Post #757429 8th Feb 2019 9:51pm
jst
i have a customer with same issue as this. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #757922 11th Feb 2019 11:56am
Defender Fun
Hi
As I seem to be getting some (few) drops of fuel when the engine is on I’m gambling changing the fuel pressure regulator and hopefully the problem will be fixed. I’m currently ordering the Bearmach replacement part now.
Kind regards
Post #757944 11th Feb 2019 1:27pm
Page 2 of 2 <12
