![]() | Home > Maintenance & Modifications > Anyone install a Frontrunner Fold Down Table ? |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 388 ![]() ![]() ![]() |
curious how you fastened it to the rear trim. Its all uneven etc so curious how you did it. My thought was to pull the trim bit and do some stainless bolts with large washers and make a metal spacer for the bottom left corner where it wouldnt be supported.
https://www.frontrunneroutfitters.com/en/u...-mk11.html |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
I've only seen this used on Defenders where folk have fitted chequer plate instead of the original trim panel - so having a completely flat surface.
Not saying it couldn't be done - just that the vehicles and pictures I've seen are with chequer plate. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 ![]() ![]() |
This guy has one
?t=703 don't think he explains how it was fitted but you might be able to get some idea |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
I was thinking about fitting this but instead I went for the Nakatanenka folding table. Quite easy installaton and no checker plate required.
https://www.defender2.net/forum/topic51267.html |
I like their stuff too, this was 1/2 the cost here in the states...
