Home > Maintenance & Modifications > Anyone install a Frontrunner Fold Down Table ?
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
curious how you fastened it to the rear trim. Its all uneven etc so curious how you did it. My thought was to pull the trim bit and do some stainless bolts with large washers and make a metal spacer for the bottom left corner where it wouldnt be supported.
https://www.frontrunneroutfitters.com/en/u...-mk11.html
Post #756429 5th Feb 2019 3:09am
donmacn
I've only seen this used on Defenders where folk have fitted chequer plate instead of the original trim panel - so having a completely flat surface.
Not saying it couldn't be done - just that the vehicles and pictures I've seen are with chequer plate. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #756456 5th Feb 2019 9:43am
drinkdrinkdrop
This guy has one
?t=703
don't think he explains how it was fitted but you might be able to get some idea
Post #756477 5th Feb 2019 12:15pm
big110
Well, I jut busted it out. Pretty straight forward. It will attach flat along the top except for the left most corner. I used a poly tube from the hardware store as a spacer. That required 1/4" spacer. Bottom left was fine, but bottom right needed 3/4" spacer too. I used all stainless hardware and big washers on both sides. The hardware was really junk that came with it so just went to hardware store and sorted it all out.
Post #756597 5th Feb 2019 9:22pm
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
I was thinking about fitting this but instead I went for the Nakatanenka folding table. Quite easy installaton and no checker plate required.
https://www.defender2.net/forum/topic51267.html
Post #756651 5th Feb 2019 11:43pm
big110
I like their stuff too, this was 1/2 the cost here in the states...
Post #756666 6th Feb 2019 1:22am
