![]() | Home > Maintenance & Modifications > Td5 transfer box and axle oils ? |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 ![]() ![]() |
I just wanted to check before buying the below oil to do 2 defenders that gl-5 ep90 will be fine for both axles and transfer box as I'm reading conflicting info?
https://www.eurocarparts.com/ecp/p/car-acc...mp;cc5_868 |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 944 ![]() ![]() ![]() |
Hi, I used Castrol syntrans 75w/90 for transfer box and Castrol EPX 80w/90 for axles. I got this from Opie oils.
Mike |
https://www.opieoils.co.uk/p-739-castrol-s...x-oil.aspx
This one @mike c ? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6004 ![]() ![]() |
That one shown is a good oil
![]() This is the yearly service supply I’ve just fitted. ![]() Click image to enlarge The Motul was in the trans box. |
That's the one Djcla for transfer box
Useful, what did you go for in gearbox? |
The R380 main gearbox should have an MTF94 oil.
The REDLINE fully synth oil is for the gearbox. Top notch stuff
![]() ![]() MOTUL for transfer box The FUCHS is for the diffs FUCHS fully synth for engine Then canister oil filter, rotary oil filter, fuel filter, and air filter. And got £26 discount as I’m a member on here. |
Cheers I might get the Landrover stuff in the hope it smooths put the gear changes |
It did on mine, it's quite hard to find the genuine stuff but I managed to on eBay, the seller was a main dealership, Harwoods and it's part no Stc 9157 printed on my invoice.
Opie oils do MTF.
https://www.opieoils.co.uk/p-147624-granvi...fluid.aspx But I was informed the RED LINE was a better oil. |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 ![]() |
The genuine stuff s not that fancy, really it is just a slightly modified 10w-40 engine oil. Back then MTF's or 75w-80 oils were not readily available so a modified 10w-40 was used. This was also handy for Defenders across the globe as no matter where in the world they are, or how remote they just needed a 10w-40 engine oil, rather than having to find a specified gear oil that might bot be available. So these days a good 75w-80 meeting API GL4 is ideal, but if you wanted to stick with the traditional stuff then the Millers Trident 10w-40 meets LandRover MTF94 https://www.opieoils.co.uk/p-60215-millers...0w-40.aspx Cheers, Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Quite a lot of places, (ashcroft included I think) recommend certain ATF's again these days |
This is useful for future reference Guy, thanks for the information on this.
Mike |
