Home > Maintenance & Modifications > Td5 transfer box and axle oils ? |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
I just wanted to check before buying the below oil to do 2 defenders that gl-5 ep90 will be fine for both axles and transfer box as I'm reading conflicting info?
https://www.eurocarparts.com/ecp/p/car-acc...mp;cc5_868 |
2nd Feb 2019 7:23pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
Hi, I used Castrol syntrans 75w/90 for transfer box and Castrol EPX 80w/90 for axles. I got this from Opie oils.
Mike |
3rd Feb 2019 9:18am |
https://www.opieoils.co.uk/p-739-castrol-s...x-oil.aspx
This one @mike c ? |
3rd Feb 2019 10:08am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
That one shown is a good oil
This is the yearly service supply I’ve just fitted. Click image to enlarge The Motul was in the trans box. |
3rd Feb 2019 10:20am |
That's the one Djcla for transfer box
3rd Feb 2019 10:46am |
Useful, what did you go for in gearbox? |
3rd Feb 2019 10:59am |
The R380 main gearbox should have an MTF94 oil.
3rd Feb 2019 11:22am |
The REDLINE fully synth oil is for the gearbox. Top notch stuff
MOTUL for transfer box The FUCHS is for the diffs FUCHS fully synth for engine Then canister oil filter, rotary oil filter, fuel filter, and air filter. And got £26 discount as I’m a member on here. |
3rd Feb 2019 12:08pm |
Cheers I might get the Landrover stuff in the hope it smooths put the gear changes |
3rd Feb 2019 12:26pm |
It did on mine, it's quite hard to find the genuine stuff but I managed to on eBay, the seller was a main dealership, Harwoods and it's part no Stc 9157 printed on my invoice.
3rd Feb 2019 12:40pm |
Opie oils do MTF.
https://www.opieoils.co.uk/p-147624-granvi...fluid.aspx But I was informed the RED LINE was a better oil. |
3rd Feb 2019 1:12pm |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 |
The genuine stuff s not that fancy, really it is just a slightly modified 10w-40 engine oil. Back then MTF's or 75w-80 oils were not readily available so a modified 10w-40 was used. This was also handy for Defenders across the globe as no matter where in the world they are, or how remote they just needed a 10w-40 engine oil, rather than having to find a specified gear oil that might bot be available. So these days a good 75w-80 meeting API GL4 is ideal, but if you wanted to stick with the traditional stuff then the Millers Trident 10w-40 meets LandRover MTF94 https://www.opieoils.co.uk/p-60215-millers...0w-40.aspx Cheers, Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
4th Feb 2019 12:04pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Quite a lot of places, (ashcroft included I think) recommend certain ATF's again these days |
4th Feb 2019 12:17pm |
This is useful for future reference Guy, thanks for the information on this.
Mike |
4th Feb 2019 12:23pm |
