Home > Maintenance & Modifications > Td5 transfer box and axle oils ?
Djcla
I just wanted to check before buying the below oil to do 2 defenders that gl-5 ep90 will be fine for both axles and transfer box as I'm reading conflicting info?
https://www.eurocarparts.com/ecp/p/car-acc...mp;cc5_868
Post #755734 2nd Feb 2019 7:23pm
landy andy
You want good stuff in the transfer box, and don’t worry too much about diff oil quality as they are very basic. The GL5 should be ok.
For more info, and a deal talk to opie oil and get the discount that you get for being here.
Post #755828 3rd Feb 2019 1:22am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi, I used Castrol syntrans 75w/90 for transfer box and Castrol EPX 80w/90 for axles. I got this from Opie oils.
Mike
Post #755841 3rd Feb 2019 9:18am
Djcla
Post #755849 3rd Feb 2019 10:08am
landy andy
That one shown is a good oil Thumbs Up
This is the yearly service supply I’ve just fitted.
The Motul was in the trans box.
Post #755853 3rd Feb 2019 10:20am
Mike c
That's the one Djcla for transfer box Thumbs Up
Post #755864 3rd Feb 2019 10:46am
Djcla
Useful, what did you go for in gearbox?
Post #755869 3rd Feb 2019 10:59am
Mike c
The R380 main gearbox should have an MTF94 oil.
Post #755875 3rd Feb 2019 11:22am
landy andy
The REDLINE fully synth oil is for the gearbox. Top notch stuff Thumbs Up Thumbs Up
MOTUL for transfer box
The FUCHS is for the diffs
FUCHS fully synth for engine
Then canister oil filter, rotary oil filter, fuel filter, and air filter.
And got £26 discount as I’m a member on here.
Post #755883 3rd Feb 2019 12:08pm
Djcla
Cheers I might get the Landrover stuff in the hope it smooths put the gear changes
Post #755888 3rd Feb 2019 12:26pm
Mike c
It did on mine, it's quite hard to find the genuine stuff but I managed to on eBay, the seller was a main dealership, Harwoods and it's part no Stc 9157 printed on my invoice.
Post #755892 3rd Feb 2019 12:40pm
landy andy
Opie oils do MTF.
https://www.opieoils.co.uk/p-147624-granvi...fluid.aspx
But I was informed the RED LINE was a better oil.
Post #755901 3rd Feb 2019 1:12pm
oilman
The genuine stuff s not that fancy, really it is just a slightly modified 10w-40 engine oil. Back then MTF's or 75w-80 oils were not readily available so a modified 10w-40 was used. This was also handy for Defenders across the globe as no matter where in the world they are, or how remote they just needed a 10w-40 engine oil, rather than having to find a specified gear oil that might bot be available.
So these days a good 75w-80 meeting API GL4 is ideal, but if you wanted to stick with the traditional stuff then the Millers Trident 10w-40 meets LandRover MTF94 https://www.opieoils.co.uk/p-60215-millers...0w-40.aspx
Cheers,
Guy Use the code DEF2 and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Post #756148 4th Feb 2019 12:04pm
miker
Quite a lot of places, (ashcroft included I think) recommend certain ATF's again these days
Post #756154 4th Feb 2019 12:17pm
Mike c
This is useful for future reference Guy, thanks for the information on this.
Mike
Post #756158 4th Feb 2019 12:23pm
