Home > Puma (Tdci) > 10AS alarm issue
Vitesse
10AS alarm issue
HI, strange fault on my 2015 Puma. The hazzard lights always flash when locking the car but more often than not they wont flash when unlocking. The actual locks are not affected and the system seems ok apart from that
Anyone suffered this particular fault? I can only assume some sort of control fault inside the 10AS perhaps? 2015 90 XS Santorini Black
Post #752627 20th Jan 2019 5:39pm
mk1collector
Possible low battery in the key fob Ray
My build thread
Post #752644 20th Jan 2019 6:56pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
afaik it is not a 10AS any more :
The Lucas 10AS alarm immobiliser is no longer available as a spare part and was changed to a similar looking unit that is black and does not have the model number 10AS on the label. This alternative black unit was fitter to vehicles from 2013 as far as I have been able to determine. It is this black unit that gives trouble and also is not available as a spare part.
The entire system is removed and replaced with a number of other components. This will include the security fob attached to the keys. Some of the electrical wiring loom has to be reconfigured as part of the repair.
( replacement of the entire Alarm immobiliser as per Technical Service bulletin LTB00893 )
https://www.aulro.com/afvb/90-110-130-defe...ase-2.html
** Note
From Mid 2013 (2014 Model Year, beginning with VIN EA000001) Land Rover replaced the 10AS with an Alarm from a different manufacturer that although is still called the 10AS and is in the same shape Case, but is Black in color and not Diagnostically compatible with the Early Lucas Green 10AS. As such this version is currently not supported.
https://www.nanocom-diagnostics.com/downlo...-evolution
Post #752659 20th Jan 2019 7:42pm
grafty99
Yes 2015 MY > have a Siemens unit I believe
Not flashing on disarming is low key fob battery warning Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #752670 20th Jan 2019 8:17pm
Julie
A 10AS is going to stop reacting occasionally if your fobs run out of power ...
Post #752672 20th Jan 2019 8:23pm
Vitesse
Thanks ! I will check the keyfob battery. 👍 2015 90 XS Santorini Black
Post #752699 20th Jan 2019 10:42pm
X4SKP
Post #752750 21st Jan 2019 11:35am
Vitesse
Cheers. I should have read the manual first. Indeed it just needed a new coin cell
Thanks for the help Thumbs Up 2015 90 XS Santorini Black
Post #752752 21st Jan 2019 11:37am
hornet
Julie wrote:
The Lucas 10AS alarm immobiliser is no longer available as a spare part and was changed to a similar looking unit that is black and [...]
Would it make sense to have a used 10as as a replacement in case of emergency, as well as a control unit? I am seriously thinking about it...!
Post #752761 21st Jan 2019 12:12pm
