![]() | Home > Maintenance & Modifications > Is it worth upgrading the intercooler? |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3361 ![]() ![]() ![]() |
Bowler use a bespoke PWR intercooler for their Stage 2 upgrade and desert spec. Pricey but probably the best you can buy.
Whether it's worth upgrading for the use you describe is debatable. |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
Allisport do them .
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6049 ![]() ![]() |
I found fitting the ultimate intercooler from Alive made no difference at all to my tuned Tdci.
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Bigger IC = cooler/more dense air = more torque in basic terms.
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Did you have the map tweaked utilize the bigger intercooler? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
Very interesting! > 110 XS Double Cab |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Intercooler alone will make little to no difference without the supporting engine calibration
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Yes, map done, swapping exhaust made much more difference. This was on a Tdci. |
Interesting, I found it made a noticeable difference... IMO less than the exhaust?
![]() I have a full sports exhaust with no cat too... This was all before hybrid turbo too Times like this i think sticking the car on the dyno and actually seeing what it's doing makes the most sense... |
BAS website says...
Key words being "thinking about" and "important when working at high engine rpm or road speeds and especially so when used in hot country’s and climates" > 110 XS Double Cab |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
I have just the standard tune, but I do have the Entreq intercooler which is identical to the Alive Tuning ultimate intercooler. No noticeable increase in performance, but the idea of lower air intake temps, i.e. lower engine running temps gives peace of mind in the summer. And together with the PEL500110 soft spring 82° thermostat the risk of overheating is sharply reduced which is a good thing.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
I don't think that upgrading the intercooler will have any effect on the engine operating temperature. Any such benefit - if measurable, is incidental.
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
I feel there was no benefit then surely there'd be no benefit of fitting an intercooler at all... I wouldn't expect a performance increase but I just thought it was healthier to have the lower intake temps on a tuned engine.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
I have the BAS hi-flow IC, but had it fitted with teh BAS 170AB remap so can't comment on if you feel any difference. I was recommended it as I tow, but Pete said it wasn't essential if not towing. However, i felt increasing power by 40% the engine must benefit from the extra cooling, not necessarily in performance but for longevity? Good oppourtunity to change to silicone hoses too... where does it stop
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
