Home > In Car Electronics > Pioneer releasing the first single-DIN unit with Carplay |
edo Member Since: 20 Aug 2018 Location: Surrey Posts: 354 |
If anyone knows where you can get that relocation panel without it, appreciate it!
21st Aug 2018 9:49pm |
buckers19 Member Since: 02 Jan 2018 Location: London Posts: 93 |
I appreciate I'm digging up an old topic here but has anyone installed this head unit into a 300TDI? Only asking as I am looking to do this but I'm concerned that the screen will interfere with the top of the dash and prevent it from unfolding fully.
6th Dec 2018 4:05pm |
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 |
I’ve got a 300 and a puma with this head unit, I doubt very much that this unit will work in the std 300 radio location,
While the screen angle can be adjusted, with the acute angle of the 300 din housing I suspect it will clash with the top rail of the dash. |
10th Dec 2018 8:09pm |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 604 |
To anyone who has installed this:
A) How the hell do you fit all those wires down behind the head unit!!!! Wish they could all be unplugged. B) Anyone had problems only having sound from one side? Speakers work fine with old head unit but new head unit I’m getting sound to left speakers and only muffled sound to right speakers. Anything that can be remedied or duff head unit? https://instagram.com/bentheoandrews |
20th Jan 2019 11:26am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
HI Farmerben,
when i fitted mine i had to carefully feed the cables back so they naturally came to rest in the correct place. It is a tricky job and i always cringe when I think I have to remove the dash for any reason. I made it easier by not using the rear fixing lug into the bracket. This helped a bit. As far as sound issues are concerend, it maybe a trapped wire causing that due to the tight space. Its possible this could have slightly shorted a cable but the fact it is muffled does tend to make that more unlikely. Could be a faulty unit. double check the audio settings first. (if not already) 2015 90 XS Santorini Black |
20th Jan 2019 4:36pm |
Thanks! I’ve ordered another wiring loom so will see if that sorts it. Such a pain because everything else is working. https://instagram.com/bentheoandrews
20th Jan 2019 6:42pm |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
Just in case anyone is interested in this head unit it has gone down to £349 on Amazon which is back down to pretty much what I paid last summer...
https://www.amazon.co.uk/gp/product/B07BKX...&psc=1 |
27th Jan 2019 7:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19449 |
I like that unit a lot. Have you added DVB-T (Digital TV unit to it too?)
It's perfectly possible using the inputs, of course you cannot use that though whilst driving but stationary parked up somewgere you could. Does it let you use Nav through the phone? Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
27th Jan 2019 7:49pm |
I haven't bothered with the TV options, not sure I'd ever use it.
Yes you can get sat nav on it from your phone, it comes with a USB cable which I fed through the dash so my phone sits nicely on the shelf on the passenger side. I use Android Auto which gives you the option of using Waze or Google Maps to navigate. As navigation options go I think it's one of the best, certainly much better than the usual LR crud that comes in their other vehicles. |
28th Jan 2019 9:22am |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 281 |
Just fitted to my car. Very pleased with the result. Added bonus that I can still get my fingers behind the screen to access covered buttons
Click image to enlarge |
2nd Oct 2020 9:27pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3459 |
That looks ace. Was looking at one for my 300TDI. So has anyone fitted one to an older Defender? 1951 80" S1 2.0
3rd Oct 2020 6:28am |
NL_Defender_90 Member Since: 07 Oct 2020 Location: NL Posts: 7 |
Hi all! (First post)
I want to install a z7200dab unit into my defender 2011. I read for models >2012 you would need an adapter cable in this thread. Do I need additional cables for my car, or is it plugged and play? Thanks, |
9th Oct 2020 7:34am |
From memory I had to buy one of these to convert from the Alpine head unit that came in MY14 to the Alpine head unit...
https://www.mudstuff.co.uk/collections/aud...1476558933 |
9th Oct 2020 7:48am |
Update: in my 2011 - 90. It was Plug&Play with connectors, no need for any iso adapter.
I do have a question, related to the 1-din mounting case that is provided with the radio. The gap in the dashboard is to narrow (left and right some metal piece are seem to block) - did you remove these pieces (they don’t come of easy)?. So basically I can’t push the 1 din mount, trough the 1 din dashboard gap. Radio goes trough fine, and is now mounted with the 1-din mounting case from the rear. Can provide pics if needed. |
12th Oct 2020 8:19am |
