Home > Maintenance & Modifications > Rear sliding window glass removal from frame?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Am I able to remove the glass out of the frame on the rear sliding windows in my 2014 station wagon
Thanks
Post #750117 9th Jan 2019 4:58am
bob neville
You can but you need to remove the frame from the vehicle and then split the frame by undoing a couple of screws.
It is quite an easy job on a pre Puma model as the frames are riveted in but the Puma frames are glued in.
I am sure if it can be done without removing the frame somebody will be along to correct me !
2013 Defender 90 CSW - sold
Post #750138 9th Jan 2019 12:06pm
big110
Ok hoping I can pop them out somehow without taking the frame out. That’s been the biggest pain ever
Post #750180 9th Jan 2019 4:05pm
Thon
I was told by my workshop that in order to change the window runners, I would have to remove the whole window frame from side panel, which as stated is bonded in and a total pain to remove.
I would presume the same for the window glass.
Hoping someone might have a simpler way?
Post #750358 10th Jan 2019 5:14pm
Merlin
Had my Puma ones cut out. Seemed no other way. Peter
Post #750535 11th Jan 2019 2:23pm
big110
You might be on to something!
Post #750537 11th Jan 2019 2:33pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
You can replace the runners without removing the glass.
I just did it on mine using this:
https://www.woolies-trim.co.uk/product/1649/small-window-channel
It usually only the bottom half that needs doing.
It slides in easy enough with a bit of silicon spray.
Post #750546 11th Jan 2019 4:02pm
big110
But I want to pull the glass all the way out
Post #750550 11th Jan 2019 4:13pm
michail1976
Russia 2014 Defender 110 Puma 2.2 CSW Oslo Blue
Re: Rear sliding window glass removal from frame?
Thanks
Post #751150 14th Jan 2019 9:05am
mcma1
I have a full set of factory privacy glass spare to sell if anyone is interested. From my old 110 so rear doors, rear sliders, and rear quarters Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #752289 19th Jan 2019 6:49am
