![]() | Home > Maintenance & Modifications > Rear sliding window glass removal from frame? |
You can but you need to remove the frame from the vehicle and then split the frame by undoing a couple of screws.
It is quite an easy job on a pre Puma model as the frames are riveted in but the Puma frames are glued in. I am sure if it can be done without removing the frame somebody will be along to correct me ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 ![]() ![]() |
Ok hoping I can pop them out somehow without taking the frame out. That’s been the biggest pain ever
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I was told by my workshop that in order to change the window runners, I would have to remove the whole window frame from side panel, which as stated is bonded in and a total pain to remove.
I would presume the same for the window glass. Hoping someone might have a simpler way? |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Had my Puma ones cut out. Seemed no other way. Peter
You might be on to something!
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
You can replace the runners without removing the glass.
I just did it on mine using this: https://www.woolies-trim.co.uk/product/1649/small-window-channel It usually only the bottom half that needs doing. It slides in easy enough with a bit of silicon spray. |
But I want to pull the glass all the way out
michail1976 Member Since: 09 Jun 2018 Location: Krasnoyarsk Posts: 3 ![]() ![]() ![]() |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2946 ![]() ![]() |
I have a full set of factory privacy glass spare to sell if anyone is interested. From my old 110 so rear doors, rear sliders, and rear quarters Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
