Home > Td5 > TD5 owner ship,
Page 3 of 9 <123456789>
Procta
Adam17 wrote:
Procta wrote:
I have heard about oil in the engine loom, Would that be fixed now? also do these have a separate water pump like the 300s?
I had oil in the loom, and subsequently ruined my ecu... But I fitted a new loom, and they are sealed, so I wont happen again. - and it was a great excuse to the wife to spend some more money on it!! Very Happy Wink Thumbs Up
How much was that to fix if you don't mind me asking? and how long did it take you to fix it? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #752191 18th Jan 2019 7:44pm
Procta
I have seen two maybe 3 possible replacments, One is down the country and the other is up the country. the other is not that far from me, Only thing that's biting me a bit is the snorkels. I am not keen, my dad had a moan at me, saying you are trying to make it like a car, I said I am not taking it off road. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #752196 18th Jan 2019 7:46pm
landy andy
As with all cars, drive as many as you can, that way you know good from bad.
Post #752204 18th Jan 2019 8:31pm
Procta
Its finding a decent one in my price range, I will have to have a chat with the bank again, at this rate we are looking at 300 tdi again Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #752216 18th Jan 2019 9:07pm
Procta
Did they change the rear axles on these during production ? Some I have seen has the same axel as the 200 and others with the same axle as the 300 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #752421 19th Jan 2019 6:04pm
landy andy
I know the later axles had cups for damper bushes, and early ones didn’t. What is the 200-300 differences that you have noticed?
Post #752424 19th Jan 2019 6:11pm
Procta
The 200s looked like they have same drive flanges all round where the 300 didn't, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #752443 19th Jan 2019 7:14pm
DSC-off
From MA vin numbers, 1994 or 1995, the rear axle changed from drum to disc brakes.
There were other changes at the same time. Different halfshafts and differential (number of splines) , wheel bearings lubriated by grease not the diff oil, oil seals added, bearings no longer adjustable (lock nuts replaced by stake nut).
After that there were various minor updates but essentially the same axle through 300tdi, td5 and puma, for the 90.
On a 110 there was a later change when the disc braked Salisbury axle was replaced by a reinforced Rover type axle.
That was a development of the Wolf military axle, though not as heavily reinforced.
Post #752524 19th Jan 2019 11:59pm
Procta
Spot on! How easy is to remove the EGR on these? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #753423 23rd Jan 2019 6:27pm
DSC-off
I'd think twice about removing a working egr these days.
Not sure on the current mot rules, but things have been tightenied up and no doubt will be again.
"Is the emissions control equipment in place and operational?" is a phrase that springs to mind.
Don't loose the bits if you do take it off!
Post #753431 23rd Jan 2019 7:21pm
lightning
The TD5 EGR can’t be seen without removing the engine cover. So it’s unlikely to cause problems at the MOT if you remove it.
Having said that, l removed mine as it was supposed to “improve performance” but l couldn’t tell any difference. Maybe if the EGR was defective you’d notice a difference, but l assume that mine was working. I since refitted it.
The EGR valve was not fitted to the TD5 in all markets.
Post #753459 23rd Jan 2019 9:08pm
landy andy
EGR, easy t9 remove, easy to reinstall, and out of sight. As mentioned you won’t notice any difference performance wise with or without if it’s working, which most are as they are a very basic thing. But then look at all the black sticky shiit that is in your inlet manifold manifold when you remove it. Mine is removed, bagged, and stored away should it be required. As with a CATs, you could remove the internals if MOTs ever become that picky, but can’t see it happening on old motors.
Post #753515 24th Jan 2019 12:04am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Easiest way is to remove one of the spacers and replace it with a solid one Whistle looks factory and can’t be noticed without pulling it apart. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #753521 24th Jan 2019 12:33am
grafty99
The difference in drive flanges could be that some have 1 piece rear drive shafts and some don't Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #753542 24th Jan 2019 9:13am
Procta
Thanks grafty for that and cheers for the info so far! I am still putting my feelers out there for our replacement one. Seen a couple but, i think we can still do a bit better, the Scottish one is blew out. Dealer never got back to me on the photos,
three are still in the mix, but one is very pricey sadly Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #753725 24th Jan 2019 9:17pm
