Home > Td5 > TD5 owner ship,
Page 6 of 9 <123456789>
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I see what you mean, I had a 300tdi years ago as my first Defender, no electronics on it to worry about.
The td5 is much nicer drive though and and the mod cons are great, it was what I wanted at the time but couldn't afford. It's a good balance between old school and modern Cool
Post #754324 27th Jan 2019 4:37pm
lightning
All Defenders were reclassified as commercial vehicles around 2011. So if you can stretch to any 2.2 TDCi you’ll pay only £230.
Some late 2.4 SW crept into the lower tax band as well. Worth checking when looking at one to buy.
Post #754366 27th Jan 2019 7:53pm
Procta
What is the air con like on these? I have seen two with air con on. Is it troublesome or worth having? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #754382 27th Jan 2019 8:53pm
Procta
The later ones are a bridge to far for me to cross sadly Sad
me and my dad had a chat yesterday, with me young enough to get a loan out, I was going to give my dad 2k to get his chassis swopped. His defender is the last ever motor he will buy now, so its his asset. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #754383 27th Jan 2019 8:56pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
My 2003 has aircon , I had a small leak on one of the pipes a couple of years ago, but since then it's been trouble free. It gives a good blast of icy air and helps with condensation. Recommended if you find one with it fitted
Post #754385 27th Jan 2019 9:09pm
Several models of 2.4 from 2007 on are also N1 with the lower tax, essentially all commercial variants (HT, PU, DCPU). Don't discount these.
Post #754418 27th Jan 2019 11:10pm
Mike c
The air con is fine and works adequately, great to have.
Post #754458 28th Jan 2019 11:40am
OsloBlue
Only problem with td5 air con is that it only cools your nuts I'm on IG: https://www.instagram.com/osloblue42/
Post #754462 28th Jan 2019 12:19pm
lightning
TD5 aircon is OK. It’s basically a big carbuncle under the dash and is separate from the heater. So it can’t blow cold air on the screen directly.
But it does work, and is worth having if you can get it. Having said that my CSW 110 doesn’t have it and l’ve not really had a problem, in the summer l just open the vents and windows.
Aircon won’t usually work below about 5deg C so in the Winter there’s not much difference.
The TDCi aircon/heater is much better, although the fan is noisy even on the lowest setting and it doesn’t have the bulkhead vents.
I would say you need aircon more in a TDCi than a TD5.
Post #754497 28th Jan 2019 2:42pm
Mike c
It's perfectly adequate despite its after thought design (I quite like it!), providing you adjust the vents so it doesn't just freeze your knees/nuts! Thumbs Up
Obviously, the tdci is a much more integrated/efficient system but it was thoroughly revised with the new dashboard.
Post #754539 28th Jan 2019 6:16pm
landy andy
As above Td5 ac works ok, and gives very very cold keys, but in a Tdci ac is a must due to no bulkhead flaps, and the fact the transmission tunnel gets stupidly hot on a long drive, which is made even worse by opening a window.
Post #754656 28th Jan 2019 10:58pm
Procta
Do these have a dual mass flywheel? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #755737 2nd Feb 2019 7:34pm
MadTom
TD5 has dual mass flywheel, bu it is not a problem, normally it survives longer than clutch. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #755742 2nd Feb 2019 7:57pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Yes, helps feather out some of that extra torque once youve got it remapped!
Post #755750 2nd Feb 2019 8:36pm
Procta
How strong are the dual mass flywheels? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #755755 2nd Feb 2019 8:48pm
