Home > Td5 > TD5 owner ship,
Page 7 of 9 <123456789>
htb2
Wales
Changed mine at 160k, towed all its life normally 3.5t Ifor full of woodchip or timber. So cant complain
Post #755765 2nd Feb 2019 9:07pm
Sulisuli
My first defender was a TD5 nicest engine by far Thumbs Up had a 2.4 and currently a 2.2 as I said TD5 nicest engine by far. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #755767 2nd Feb 2019 9:14pm
Procta
Are the heaters any different compared to the TDi series or is just the same? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #757205 7th Feb 2019 10:14pm
Retroanaconda
Minor improvements to blower and flaps arrangements but basically the same design.
Perfectly adequate, but not up to the performance level of modern vehicles.
Post #757218 7th Feb 2019 10:42pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
As above, perfectly adequate and effective if working correctly, contrary to the popular myth that all pre 2007 heaters are useless! My old TDI heater was fine as well.
The other important thing to keeping the cab warm is to ensure all door/vent flap seals are in good condition so you are not getting huge draughts in and letting all heat out (I am sure you already know that! Thumbs Up
Mike
Post #757336 8th Feb 2019 5:03pm
Procta
cheers lads Thumbs Up What about the oil in the loom thing? is that sorted now or can that still happen? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757366 8th Feb 2019 7:36pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
My understanding is it can still happen I changed mine last year when i bought my TD5 as oil had migrated along the ECU lead.
It is easy and cheap to replace and maybe should be considered a service item every couple of years.
In extreme cases if left it can destroy your ECU with oil contamination. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #757392 8th Feb 2019 8:41pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I had the oil ingress, killed off my ECU Big Cry Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #757517 9th Feb 2019 1:30pm
Procta
Is the clutch system the same as the 300 TDI? and also the trans brake shoes etc? I know there is a difference with the 200. I bought the spares off my dad, due to him ordering the wrong items. I am starting to sort out spares that i don't need now. Sad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757561 9th Feb 2019 6:04pm
grafty99
The clutch is different. Dual mass Flywheel on a Td5 as standard Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #757563 9th Feb 2019 6:08pm
Procta
Ok what about the master and slave cylinder? i do have either both or the master for the 300 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757567 9th Feb 2019 6:17pm
grafty99
I would imagine the master is the same, the slave most likely not. But don't quote me on that Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #757577 9th Feb 2019 6:33pm
Retroanaconda
Master the same, slave different indeed. But same basic system.
The Td5 has a far superior clutch lever though, it uses the same cast item as the V8 rather than the crappy pressed tin Tdi version.
Post #757585 9th Feb 2019 7:09pm
Procta
spot on, i will have to see what needs to go then, How are these like to drive compared to the 300 TDI? i know the notchy 2nd gear. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #757604 9th Feb 2019 8:44pm
Retroanaconda
It’s the same gearbox as on a 300Tdi so not sure there’s anything specific about a Td5 giving a notch second gear.
They’re a nice engine to drive I find. More torque than a Tdi but different rev characteristics so you do change how you drive. But the only way to find out is to try some.
Post #757623 9th Feb 2019 9:33pm
