Home > Td5 > TD5 owner ship, |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
Changed mine at 160k, towed all its life normally 3.5t Ifor full of woodchip or timber. So cant complain
2nd Feb 2019 9:07pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
Are the heaters any different compared to the TDi series or is just the same? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
7th Feb 2019 10:14pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
Minor improvements to blower and flaps arrangements but basically the same design.
Perfectly adequate, but not up to the performance level of modern vehicles. |
7th Feb 2019 10:42pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
As above, perfectly adequate and effective if working correctly, contrary to the popular myth that all pre 2007 heaters are useless! My old TDI heater was fine as well.
The other important thing to keeping the cab warm is to ensure all door/vent flap seals are in good condition so you are not getting huge draughts in and letting all heat out (I am sure you already know that! Mike |
8th Feb 2019 5:03pm |
cheers lads What about the oil in the loom thing? is that sorted now or can that still happen? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th Feb 2019 7:36pm |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
My understanding is it can still happen I changed mine last year when i bought my TD5 as oil had migrated along the ECU lead.
It is easy and cheap to replace and maybe should be considered a service item every couple of years. In extreme cases if left it can destroy your ECU with oil contamination. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
8th Feb 2019 8:41pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
I had the oil ingress, killed off my ECU Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
9th Feb 2019 1:30pm |
Is the clutch system the same as the 300 TDI? and also the trans brake shoes etc? I know there is a difference with the 200. I bought the spares off my dad, due to him ordering the wrong items. I am starting to sort out spares that i don't need now. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Feb 2019 6:04pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
The clutch is different. Dual mass Flywheel on a Td5 as standard 2002 90 Td5 Station Wagon
9th Feb 2019 6:08pm |
Ok what about the master and slave cylinder? i do have either both or the master for the 300 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Feb 2019 6:17pm |
I would imagine the master is the same, the slave most likely not. But don't quote me on that 2002 90 Td5 Station Wagon
9th Feb 2019 6:33pm |
Master the same, slave different indeed. But same basic system.
The Td5 has a far superior clutch lever though, it uses the same cast item as the V8 rather than the crappy pressed tin Tdi version. |
9th Feb 2019 7:09pm |
spot on, i will have to see what needs to go then, How are these like to drive compared to the 300 TDI? i know the notchy 2nd gear. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Feb 2019 8:44pm |
It’s the same gearbox as on a 300Tdi so not sure there’s anything specific about a Td5 giving a notch second gear.
They’re a nice engine to drive I find. More torque than a Tdi but different rev characteristics so you do change how you drive. But the only way to find out is to try some. |
9th Feb 2019 9:33pm |
