![]() | Home > Puma (Tdci) > Diagnostic tester |
| John64 Member Since: 10 Sep 2018 Location: Tayport Posts: 38
I recently bought the Hawkeye which is unlocked to all land rover vehicles so it works on my '08 Defender and my '14 Freelander.
| ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282
Any cheap scanner will tell you the code, but no description and most won't clear it once you've fixed the issue.
I use ForScan, free software designed for Ford engines. All you need to buy is a £20 USB to OBD2 cable (it has to be the right spec though so check the ForScan site). I got mine from eBay off the back of a thread here. You can read/reset all codes and see their descriptions. Also execute service functions such as pump learn. Also see live data, save it, graph it - great for comparing before and after a part change. I think they are developing a mobile app one day I read. Only downside is it won't connect to 10AS alarm unit, as it's designed for Ford, but unless you want that feature you can save a load of cash. I also use the software on my old man's Transits and the Mrs Fiesta. It's amazing and never had an issue! Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 |
I would not take cheap stuff, but something suitable. I have the nanocom and am very satisfied. Scope see here: https://www.nanocom-diagnostics.com/produc...7-2014-kit |
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
That’s brilliant, i did think of buying a small unit but this saves some cash Found the OBD connector on eBay; https://rover.ebay.com/rover/0/0/0?mpre=ht...3070327324 |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
if you haven;t seen these...
https://www.defender2.net/forum/topic38873.html and https://www.defender2.net/forum/topic10829.html I have a GAP Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
That's the one I have yes! Was about to posts picture but you beat me to it I used mine again to day to clear MAF fault and do pump relearn etc. after VCV change for a friend. Done in 15mins and running sweet now. Before and after values taken as well to see the improvement in real time Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
| All times are GMT |
