Home > Puma (Tdci) > Diagnostic tester
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Diagnostic tester
Engine management light has come on drives ok anybody know of a good diagnostic tester for 2.4 tdci
Thanks bunny
Post #750143 9th Jan 2019 12:50pm
John64
Scotland 2008 Defender 90 Puma 2.4 PU Tonga Green
I recently bought the Hawkeye which is unlocked to all land rover vehicles so it works on my '08 Defender and my '14 Freelander.
Post #750150 9th Jan 2019 1:14pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Any cheap scanner will tell you the code, but no description and most won't clear it once you've fixed the issue.
I use ForScan, free software designed for Ford engines. All you need to buy is a £20 USB to OBD2 cable (it has to be the right spec though so check the ForScan site). I got mine from eBay off the back of a thread here.
You can read/reset all codes and see their descriptions. Also execute service functions such as pump learn. Also see live data, save it, graph it - great for comparing before and after a part change.
I think they are developing a mobile app one day I read.
Only downside is it won't connect to 10AS alarm unit, as it's designed for Ford, but unless you want that feature you can save a load of cash.
I also use the software on my old man's Transits and the Mrs Fiesta. It's amazing and never had an issue! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #750463 10th Jan 2019 11:33pm
hornet
Re: Diagnostic tester
Thanks bunny
I would not take cheap stuff, but something suitable. I have the nanocom and am very satisfied. Scope see here: https://www.nanocom-diagnostics.com/produc...7-2014-kit
Post #750557 11th Jan 2019 4:42pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
That’s brilliant, i did think of buying a small unit but this saves some cash Thumbs Up
Found the OBD connector on eBay;
https://rover.ebay.com/rover/0/0/0?mpre=ht...3070327324
Post #750565 11th Jan 2019 5:43pm
MartinK
if you haven;t seen these...
https://www.defender2.net/forum/topic38873.html
and
https://www.defender2.net/forum/topic10829.html
I have a GAP Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #750566 11th Jan 2019 6:01pm
ozzie1989
That's the one I have yes! Was about to posts picture but you beat me to it Razz
I used mine again to day to clear MAF fault and do pump relearn etc. after VCV change for a friend. Done in 15mins and running sweet now. Before and after values taken as well to see the improvement in real time Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Post #750609 11th Jan 2019 8:53pm
