Home > Camping, Caravanning and Holidays > Running mains hook up into a Defender
Page 3 of 4 <1234>
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Thanks Gents Thumbs Up
Post #749638 6th Jan 2019 9:02pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Well the bits have arrived from Farnell
And they look like they should fit quite nicely
Now to see if I can get a plate made to fit inside the KBX frame and cut with a hole for mounting the Powercon ports.
I'm most impressed with the size compared to the 16A blue plugs and sockets I'm used to using. I went for the combined inlet/outlet in the end so that I can have power inside the Defender and plug the other half of my existing hookup cable into the outlet and have 240v available outside as well. Keith
Post #750813 12th Jan 2019 10:15pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
looking forward to how you wire this all up, are you using the hook up to charge an aux battery?
Post #750826 12th Jan 2019 10:47pm
Keith5
The plan is to run a length of 3 core flex from the blades on the rear of the socket into the rear of the USW and install a 3 gang outlet in the load space.
The sockets will be used for the ARB fridge, Coffee maker and a C-tek that I'll plug into the 12v socket, that normally runs the ARB in the load space to top up the Aux battery while we're camping. The awning lights and scenelights along with the USB outlets are all off the Aux battery already.
I'll post some photos once I get it fitted. Keith
Post #750831 12th Jan 2019 11:11pm
Badger110
I don't have a fridge or a coffee machine Mr. Green
I like the idea of a hook up to a battery charger to keep the aux battery topped up though overnight as we'll be using the lights, Usb and heater an awful lot next month.
Post #750856 13th Jan 2019 12:43am
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
So,
Is it a good idea to run the mains cable between the under seat boxes in place of the wire going from the battery to the alarm?
And make sure you don’t have any breakers on the feed from the house Wink
Post #750999 13th Jan 2019 7:09pm
seriesonenut
Only if it is 415v three phase Thumbs Up 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #751006 13th Jan 2019 7:25pm
Keith5
Little bit of time with the dremel and it now fits.
Just need to finish of the cut edges and fill the rear of the rib that I cut, probably best not to Epoxy in the kitchen.
Doesn't protrude too far to the ear so plenty space for the cable behind it.
Now just need to get some M3 bolts/screws and make up a plate to go on the rear so that I can sandwich the remains of the KBX grill between the Powercon and the plate. Keith
Post #751041 13th Jan 2019 8:58pm
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Would these be 'quick release' in case anyone drove off without remembering to disconnect it?
Post #751045 13th Jan 2019 9:07pm
Keith5
I believe they are classed as a locking connection, there are people on here more knowledgeable than me who will be able to confirm.
That was one of my considerations when I decided to mount it in the redundant wing vent, it's right next to the drives door so pretty obvious. In our case the foxwing may also be a bit of a hint before trying to drive away. Keith
Post #751049 13th Jan 2019 9:12pm
Badger110
They lock into position...if you drive off you'll rip everything off before these plugs disconnect Laughing Thumbs Up
Post #751120 13th Jan 2019 11:35pm
If you fit mains wiring to your Defender in this way, should the vehicle structure be connected to mains earth? I am aware that BS7671:2018 (18th Edition IET Wiring Regs) sas quite a lot about mains wiring into caravans and motorhome, which I imagine is applicable to this case, but I don't have a copy to hand to check.
Anyone know?
Post #751123 13th Jan 2019 11:44pm
Mo Murphy
Any progress with the installation Keith ?
Post #751673 16th Jan 2019 1:18pm
Keith5
Mo
Got the vent grill modified and will get that mounted in the next day or two. I'll get some pics posted.
I'm seeking some guidance from a friendly Electrical engineer on 18th edition. So far it looks like fitting an inline 30mA RCD is the way to go, just after the Powercon panel.
I'm now looking into options for outlets in the rear. Powercube with USB looks like a nice compact option. Keith
Post #751716 16th Jan 2019 5:08pm
Caterham
I'd question whether you need a 30mA breaker as I suspect all outlet feeding this will already be fitted with a RCD assuming they comply with current regs. I believe regs for the last circa 20 years and more had required the use of RCD for anything that might be used for something external.
I guess better safe than sorry and all that but something to consider all the same.
If your having multiple circuits / MCB perhaps look to change them for RCBO's.
food for thought.
Post #751718 16th Jan 2019 5:14pm
Page 3 of 4 <1234>
