Home > Camping, Caravanning and Holidays > Running mains hook up into a Defender |
5th Jan 2019 8:59pm |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
I have placed a 220V socket supplied by Calix and this powers block heater, cabin heater, battery charger as well as refrigirator (12/220V).
Click image to enlarge |
6th Jan 2019 12:22am |
Would either of these fit the old air intake.
https://www.leisureshopdirect.com/caravan-...new-design https://www.leisureshopdirect.com/caravan-...nlet-black Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Jan 2019 11:37am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
ARC99
That first one looks like it might just work. Will need to see about getting a plate made up and a hole cut to suit but should be easy enough using the old grill as a template. Will just need to measure the depth of the space behind. If not then it will be the surface mount socket on the rear cross member. Thanks for all the links and suggestions. Keith |
6th Jan 2019 12:44pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
A very interesting thread. I too would like to fit a 240v hook up for fridge running and battery charging on several day stops at campsites.
All of the info so far has been really useful, my only query being the suitability of these external mount connections with regard to water ingress. Are they reliably watertight ? Is there electrical risk if they are wet ? Or is the best option to install behind a watertight door. TIA Mo The Land Rover 90 - Many are called, few are chosen. |
6th Jan 2019 2:21pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
No no no and NO. That type of cable is called a widow maker for a reason. I see them occasionally as an event sparks and I chop them up into little pieces before presenting them back to their owner. I've recently fitted a neutrik powercon true1 to the rear quarter of mine, just below the sidelight. Much smaller than a 16A commando! It runs to a 4 way in the load space and has a charger connected, and gets used on said events for me to sit in the boot with my laptop and a coffee machine! |
6th Jan 2019 2:45pm |
Point taken on the male to male cable......
Could you share a photo of the powerCon port you fitted? Keith |
6th Jan 2019 4:03pm |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 |
the powerCon looks the best i have seen so far. I presume the links to the amazon ones below are OK?
Link 1 - power cable https://www.amazon.co.uk/Neutrik-PowerCON-...rcon+true1 Link 2 - chassis connector https://www.amazon.co.uk/s/ref=nb_sb_noss?...ock+System Andy Defender Td5 XS90 |
6th Jan 2019 5:26pm |
Powercon does look good, I wonder if you can get them with some sort of dust cap/cover for keeping them clean.
That will be this evening's internet searching...... Keith |
6th Jan 2019 6:02pm |
Oh yes
Dust covers available https://www.google.com/search?q=Powercon+T...t470SSq3M: Defender Td5 XS90 |
6th Jan 2019 6:38pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1025 |
Yes and they won't get wet if you fit them correctly. They are the industry standard external fitting for single and 3 phase electrics...running them for your 12v/240v needs will be more than safe |
6th Jan 2019 7:56pm |
Lots of ideas and lots to think about, thanks all for sharing ideas and knowledge.
My favourite at the moment is the Powercon system. Based on the drawings and dimensions I reckon I should be able to install one of the dual inlet and outlet units where the engine air intake used to be in the wing. One of these: https://www.canford.co.uk/Products/42-0406...-connector Lets me run a cable onto the inlet with out the dual male plug issue identified and gives a convenient 240v outlet back out the vehicle if I want it. Now to find a local fabricator to make me a nice replacement for the KBX grille that I can get powder coated that will house the dual panel connector (ideally slightly recessed slightly into the wing to protect it from branches when off road) Keith |
6th Jan 2019 8:02pm |
They have also recently started making the top (total outdoor protection) variants, which have a higher IP rating.
I'll get a photo of mine up soon! Worth buying from rs, farnell or similar, there's a lot of counterfeit neutrik stuff on eBay and the like! |
6th Jan 2019 8:45pm |
I'd completely forgotton about Neutrik!
I still have a bundle of JBL Neutrik 8 connectors somewhere, although not the correct powercon version Good tip Miker |
6th Jan 2019 8:57pm |
