Home > Camping, Caravanning and Holidays > Running mains hook up into a Defender
Page 2 of 4 <1234>
dorsetsmith
^^^ Thumbs Up
Post #749456 5th Jan 2019 8:59pm
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
I have placed a 220V socket supplied by Calix and this powers block heater, cabin heater, battery charger as well as refrigirator (12/220V).
Post #749504 6th Jan 2019 12:22am
AndrewS
Mains Hook Up Inlet Socket - Caravan / Motorhome / Campervan Flush Fitting Black 130's have feeling's as well you know Smile
Post #749505 6th Jan 2019 12:30am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Would either of these fit the old air intake.
https://www.leisureshopdirect.com/caravan-...new-design
https://www.leisureshopdirect.com/caravan-...nlet-black Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #749535 6th Jan 2019 11:37am
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
ARC99
That first one looks like it might just work. Will need to see about getting a plate made up and a hole cut to suit but should be easy enough using the old grill as a template. Will just need to measure the depth of the space behind.
If not then it will be the surface mount socket on the rear cross member.
Thanks for all the links and suggestions. Keith
Post #749545 6th Jan 2019 12:44pm
Mo Murphy
A very interesting thread. I too would like to fit a 240v hook up for fridge running and battery charging on several day stops at campsites.
All of the info so far has been really useful, my only query being the suitability of these external mount connections with regard to water ingress.
Are they reliably watertight ? Is there electrical risk if they are wet ? Or is the best option to install behind a watertight door.
TIA
50 Shades of Pennine Grey
Post #749554 6th Jan 2019 2:21pm
miker
Keith5 wrote:
I think I prefer the look of the socket with the cover for mounting on the vehicle and then carry a male to male cable to make the connection.
No no no and NO.
That type of cable is called a widow maker for a reason. I see them occasionally as an event sparks and I chop them up into little pieces before presenting them back to their owner.
I've recently fitted a neutrik powercon true1 to the rear quarter of mine, just below the sidelight. Much smaller than a 16A commando! It runs to a 4 way in the load space and has a charger connected, and gets used on said events for me to sit in the boot with my laptop and a coffee machine!
Post #749557 6th Jan 2019 2:45pm
Keith5
Point taken on the male to male cable......
Could you share a photo of the powerCon port you fitted? Keith
Post #749569 6th Jan 2019 4:03pm
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
the powerCon looks the best i have seen so far. I presume the links to the amazon ones below are OK?
Link 1 - power cable https://www.amazon.co.uk/Neutrik-PowerCON-...rcon+true1
Link 2 - chassis connector https://www.amazon.co.uk/s/ref=nb_sb_noss?...ock+System
Andy Defender Td5 XS90
Post #749584 6th Jan 2019 5:26pm
Keith5
Powercon does look good, I wonder if you can get them with some sort of dust cap/cover for keeping them clean.
That will be this evening's internet searching...... Keith
Post #749594 6th Jan 2019 6:02pm
Force64
Oh yes
Dust covers available
https://www.google.com/search?q=Powercon+T...t470SSq3M: Defender Td5 XS90
Post #749597 6th Jan 2019 6:38pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Yes and they won't get wet if you fit them correctly.
They are the industry standard external fitting for single and 3 phase electrics...running them for your 12v/240v needs will be more than safe Thumbs Up
Post #749618 6th Jan 2019 7:56pm
Keith5
Lots of ideas and lots to think about, thanks all for sharing ideas and knowledge.
My favourite at the moment is the Powercon system. Based on the drawings and dimensions I reckon I should be able to install one of the dual inlet and outlet units where the engine air intake used to be in the wing.
One of these: https://www.canford.co.uk/Products/42-0406...-connector
Lets me run a cable onto the inlet with out the dual male plug issue identified and gives a convenient 240v outlet back out the vehicle if I want it.
Now to find a local fabricator to make me a nice replacement for the KBX grille that I can get powder coated that will house the dual panel connector (ideally slightly recessed slightly into the wing to protect it from branches when off road) Keith
Post #749621 6th Jan 2019 8:02pm
miker
They have also recently started making the top (total outdoor protection) variants, which have a higher IP rating.
I'll get a photo of mine up soon!
Worth buying from rs, farnell or similar, there's a lot of counterfeit neutrik stuff on eBay and the like!
Post #749631 6th Jan 2019 8:45pm
Badger110
I'd completely forgotton about Neutrik!
I still have a bundle of JBL Neutrik 8 connectors somewhere, although not the correct powercon version Smile
Good tip Miker Thumbs Up
Post #749634 6th Jan 2019 8:57pm
Page 2 of 4 <1234>
