Home > Maintenance & Modifications > Snapped rear one piece half shaft.
Page 2 of 2 <12
Co1
Mo. I am not comparing to two like for like, one is wear and tear and the other is shock induced as you say.
I am not an armchair expert, having only racked up months as a defender owner. However I am an engineer and understand just how much load, shock or otherwise, is required to snap a shaft of those dimensions. My surprise is that this element is the weakest link of the chain, but that’s Land Rover ownership for you; full of surprises. My expectations would be that the worn splines at the drive member end would give up completely first under shock loading, not the shaft and that the probability would increase as wear increased. This was highlighted to me when I posed the question of my own on whether I go one piece or standard, and seems perfectly logical.
However, as you say you have plenty of real world experience of snapping drive shafts, so you don’t need my views on the subject. Have a happy new year (what’s left of it) and a healthy 2019.
All the best
Col
Post #748501 1st Jan 2019 4:57pm
htb2
Wales
https://www.gumtree.com/p/car-replacement-...1325317139
2 Set's of one piece discovery 1 or 90 24 spline rear shafts on gumtree at the moment, see above
Post #748515 1st Jan 2019 6:03pm
sako243
Sounds like either a change in driving style and/or visit to Nige are in order Whistle
OK I'm running 32" tyres not 33" but done some pretty extensive offroading with wheel spinning but never broken a half shaft, maybe I'm just more sympathetic. Not sure I want to find out what my weak point is now I've got pegged Ashlockers, Ashcroft halfshafts, CVs and drive members all round. Probably the gearbox Confused
But then again with three lockers don't tend to spin the wheels. If I am chances are I'm in Scotland trying to retrieve a deer and I'm stuck in a peat bog where there's no worry about finding traction Laughing Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #748529 1st Jan 2019 7:27pm
Mo Murphy
Col,
That's cool mate.
It's always better that weak spot is somewhere relatively easy to get to 😊
Broken half-shafts don't generally happen on vehicles predominantly used on-road.
It happens laning or off roading where a spinning wheel is suddenly stopped, the bigger the wheel the greater the shock.
If you want long lasting drive flanges, fit a double lipped hub seal, remove the stub axle seal and let the diff oil lubricate the wheel bearings and drive flange splines. Thats how it was originally designed to run. Or just fit one piece Wink
If you want to go mud plugging fit Ashcroft shafts and flanges. You won't break shafts then but you will move the weak spot to a more expensive and inaccessible place. But they are shiny and you will earn bragging rights Wink
Personally I have a pegged rear locker but use the half-shafts as fusible links that will break before something more expensive or inconvenient does.
Good luck with your defender ownership, remember that the drive trains were designed in the sixties to be simple and easy to fix in the field.
Happy new year
50 Shades of Pennine Grey
Post #748533 1st Jan 2019 8:14pm
miker
Assuming your shafts and flanges are in good condition, I'd say your just as likely to snap a one piece shaft as a 2 piece. You don't see many faures where the splines have been sheared by a single event, more many miles of wear.
The improved manners of one less sloppy splined joint would be lovely! Sadly I have a Salisbury and one piece shafts aren't an option Crying or Very sad
Post #748538 1st Jan 2019 8:37pm
JWL
↑↑↑↑↑↑ @miker What am I missing? My 2002 110 Td5 has a Salisbury fitted and I have a one piece half shaft in the short side and it's been in there a fair few 1000 miles.
Post #748557 1st Jan 2019 9:33pm
miker
I think it's me that's missing! I thought the one piece shafts were only available for the rover type diffs?!
Post #748561 1st Jan 2019 9:41pm
JWL
They're the same that have been fitted to the 200/300tdi Discovery's Wink
Post #748564 1st Jan 2019 9:46pm
miker
Well then. I suspect mine are worn, guess I have some shopping to do!
Post #748565 1st Jan 2019 9:48pm
IIRC, Ashcroft do a warranty against breakage which I think was either 1 or 2 years.
I think it was 2 years but does exclude fretting. (Understandable.)
What does LR have warranty wise for Genuine, I'd image there is some kind of failiure warranty? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #748580 1st Jan 2019 10:19pm
WindyJ
Think Ashcroft is 5yrs....doubt LR match anything near that.
Post #748586 1st Jan 2019 10:45pm
Page 2 of 2 <12
