Home > Maintenance & Modifications > Snapped rear one piece half shaft. |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 511 |
https://www.gumtree.com/p/car-replacement-...1325317139
2 Set's of one piece discovery 1 or 90 24 spline rear shafts on gumtree at the moment, see above |
1st Jan 2019 6:03pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1197 |
Sounds like either a change in driving style and/or visit to Nige are in order
OK I'm running 32" tyres not 33" but done some pretty extensive offroading with wheel spinning but never broken a half shaft, maybe I'm just more sympathetic. Not sure I want to find out what my weak point is now I've got pegged Ashlockers, Ashcroft halfshafts, CVs and drive members all round. Probably the gearbox But then again with three lockers don't tend to spin the wheels. If I am chances are I'm in Scotland trying to retrieve a deer and I'm stuck in a peat bog where there's no worry about finding traction Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
1st Jan 2019 7:27pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2098 |
Col,
That's cool mate. It's always better that weak spot is somewhere relatively easy to get to π Broken half-shafts don't generally happen on vehicles predominantly used on-road. It happens laning or off roading where a spinning wheel is suddenly stopped, the bigger the wheel the greater the shock. If you want long lasting drive flanges, fit a double lipped hub seal, remove the stub axle seal and let the diff oil lubricate the wheel bearings and drive flange splines. Thats how it was originally designed to run. Or just fit one piece If you want to go mud plugging fit Ashcroft shafts and flanges. You won't break shafts then but you will move the weak spot to a more expensive and inaccessible place. But they are shiny and you will earn bragging rights Personally I have a pegged rear locker but use the half-shafts as fusible links that will break before something more expensive or inconvenient does. Good luck with your defender ownership, remember that the drive trains were designed in the sixties to be simple and easy to fix in the field. Happy new year Mo The Land Rover 90 - Many are called, few are chosen. |
1st Jan 2019 8:14pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1760 |
Assuming your shafts and flanges are in good condition, I'd say your just as likely to snap a one piece shaft as a 2 piece. You don't see many faures where the splines have been sheared by a single event, more many miles of wear.
The improved manners of one less sloppy splined joint would be lovely! Sadly I have a Salisbury and one piece shafts aren't an option |
1st Jan 2019 8:37pm |
ββββββ @miker What am I missing? My 2002 110 Td5 has a Salisbury fitted and I have a one piece half shaft in the short side and it's been in there a fair few 1000 miles.
1st Jan 2019 9:33pm |
I think it's me that's missing! I thought the one piece shafts were only available for the rover type diffs?!
1st Jan 2019 9:41pm |
They're the same that have been fitted to the 200/300tdi Discovery's
1st Jan 2019 9:46pm |
Well then. I suspect mine are worn, guess I have some shopping to do!
1st Jan 2019 9:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
IIRC, Ashcroft do a warranty against breakage which I think was either 1 or 2 years.
I think it was 2 years but does exclude fretting. (Understandable.) What does LR have warranty wise for Genuine, I'd image there is some kind of failiure warranty? Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
1st Jan 2019 10:19pm |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
Think Ashcroft is 5yrs....doubt LR match anything near that.
1st Jan 2019 10:45pm |
