Home > In Car Electronics > Reversing sensor kit recomendation
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I know this has ben covered before in the past but after S.H.M.B.O. reversed into a new Disco causing over £1000.00 damage to the Defender, new rear door, wheel carrier, hinges and on the insistence of the insurance company a new spare tyre. I'm looking to fit sensors to it after it has been repaired.
What I'm looking for is something that is easy to fit as I'm still recovering from major surgery, minimum drilling and works .
I would fit a rear view camera but as she is unable to use all three mirrors when reversing adding something else for her to look at would just cause more confusion. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #747884 29th Dec 2018 11:46am
WindyJ
£20 off ebay. Inch perfect. No need to spend more, all more or less the same.
Post #747888 29th Dec 2018 12:27pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Have you got a link WindyJ? And have you used this one before/currently? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #747890 29th Dec 2018 12:32pm
WindyJ
Not on my Defender because that came with a reversing camera. Have put a couple of kits onto work pick-ups though and never had an issue or spent over £20. https://www.ebay.co.uk/itm/Reverse-Rear-Pa...SwUwlbBC0w
Post #747898 29th Dec 2018 1:07pm
Adam17
Oh ok cheers bud.. Regards
Adam
Loving The Duchess
Post #747905 29th Dec 2018 1:56pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I have a self inflating woopie cushion taped to my tow hitch, works a treat, I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #747911 29th Dec 2018 2:37pm
Adam17
Love it! Regards
Adam
Loving The Duchess
Post #747912 29th Dec 2018 2:39pm
ARC99
Not an easy fit, would require brackets fabricating or drilling holes in the rear crossmember. Don't make old people mad.
Richard
Post #748014 30th Dec 2018 11:26am
dgardel
Italy
look at this https://www.dolphinparkingsensors.co.uk/product/dolphin-das400
Installed on my several years ago!!! I'm happy with it!
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #748015 30th Dec 2018 11:27am
ARC99
dgardel.
Can I ask if it came with the brackets, did you drill the outside corners if not is the adhesive still working? Don't make old people mad.
Richard
Post #748020 30th Dec 2018 11:35am
dgardel
Italy
no brackets inside the kits.
The adhesive it's very strong, installed mine on 2010-2011 with the adhesive, never had problems, also with the high pressure washing...
I made myself the centrals sensor brackets (screwed on existing NAS step small plate/mounting points)
This is a late 2018 pic
IID Pro MV License
Post #748021 30th Dec 2018 11:42am
