Home > In Car Electronics > Reversing sensor kit recomendation |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
£20 off ebay. Inch perfect. No need to spend more, all more or less the same.
29th Dec 2018 12:27pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Have you got a link WindyJ? And have you used this one before/currently? Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
29th Dec 2018 12:32pm |
Not on my Defender because that came with a reversing camera. Have put a couple of kits onto work pick-ups though and never had an issue or spent over £20. https://www.ebay.co.uk/itm/Reverse-Rear-Pa...SwUwlbBC0w
29th Dec 2018 1:07pm |
Oh ok cheers bud.. Regards
29th Dec 2018 1:56pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
I have a self inflating woopie cushion taped to my tow hitch, works a treat, I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
29th Dec 2018 2:37pm |
Love it! Regards
29th Dec 2018 2:39pm |
Not an easy fit, would require brackets fabricating or drilling holes in the rear crossmember. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
30th Dec 2018 11:26am |
look at this https://www.dolphinparkingsensors.co.uk/product/dolphin-das400
Installed on my several years ago!!! I'm happy with it! Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
30th Dec 2018 11:27am |
dgardel.
Can I ask if it came with the brackets, did you drill the outside corners if not is the adhesive still working? Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
30th Dec 2018 11:35am |
no brackets inside the kits.
The adhesive it's very strong, installed mine on 2010-2011 with the adhesive, never had problems, also with the high pressure washing... I made myself the centrals sensor brackets (screwed on existing NAS step small plate/mounting points) This is a late 2018 pic Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
30th Dec 2018 11:42am |
