Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
So I spent my day, the morning at least, replacing the indicator stalk.
All is working good now. ![]() Click image to enlarge ![]() Click image to enlarge Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Liam Member Since: 14 Nov 2016 Location: Rotterdam Posts: 32 ![]() ![]() |
Tested stage 1 tune in combination with the new gear box & transfer case from Ashcroft. Quite easily ran up to 90+ mph
Yulong Member Since: 18 Nov 2017 Location: Aberdeen Posts: 110 ![]() ![]() |
Given its pre-Xmas wash!
Soner Member Since: 12 Sep 2018 Location: Athens Posts: 38 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge Tachometer |
mermade Member Since: 08 Dec 2018 Location: cheshire Posts: 3 ![]() ![]() |
ordered some powerflex shock bushes to have a crack at fitting over winter!
https://powerflexstore.co.uk/land-rover/defender-2002-2016/ |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1246 ![]() ![]() |
Another year - another tree
![]() Click image to enlargetree by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Room for a much bigger tree there. ![]() |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 798 ![]() ![]() ![]() |
I used mine as a mobile work platform to put the Christmas lights in a tree at my parents and then put their LED Tree on the porch.
Thank heavens for a fully decked Brownchurch rack ![]() Wide Track Sankey- In bits- Gone to a new home M0XQS |
must try harder........................
![]() Click image to enlarge0_CaptureJPG by Richard Holmes, on Flickr 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
![]() ![]() ![]() He's going to need a lot of tinsel and lights to decorate that. |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 175 ![]() ![]() ![]() |
Finally completed this over the last few days and I’m really happy with it.
Somehow with the Puma Defender I just can’t see enough behind me for parking – must be some kind of optical illusion as it’s exactly the same dimensions as the 300Tdi and I had no problems there 🙂 Anyway, fairly straightforward to fit – The ‘Garmin BC™ 30 Wireless Backup Camera’ is powered by the reversing light with a small transmitter unit tucked away behind the rear left speaker. For the Head unit (Garmin Sat Nav) I dropped the power cable with inline receiver behind the dash. The cigarette lighter type plug also converts from 12V to 5V - so I’m using a 12V cigarette lighter socket with a flylead hooked up to a fuse tap. All tucked up by the fuse box so nicely out of sight. Not a bad setup and works really well – unit switches between Sat Nav and camera as soon as you stick it into reverse. No more crossing fingers and winging it when parking ![]() I also managed to pick up a used SVX type Garmin mount but I'm not sure I fancy drilling the 2 holes in the dash - maybe another day..... ![]() ![]() ![]() Andy... Edinburgh, Scotland http://24heuer.com |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
24Heuer, I have exactly the same system in mine and really pleased with it, good picture clarity too.
I also had the original SVX mount and tried it with this screen but the size and weight of the screen on the SVX mount meant it kept tipping forward if I went over and uneven road surface (living in Cornwall that’s every road surface ![]() And yes I did drill the two holes to try it. ![]() 2008 SVX 90 2000 XS TD5 90 |
Ha! Sulisuli, good info - thanks.
I think I'll be sticking with the windscreen mount for now then ![]() It has totally changed my parking experience btw - parallel kerbside parking in the dark was easy last night! ![]() Andy... Edinburgh, Scotland http://24heuer.com |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3723 ![]() ![]() ![]() |
Wheel spacers for me this weekend. Only 30mm but makes a big difference.
