Home > Off Topic > Removing stubborn nuts with heat
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
Hi guys,
Anyone got experience of using a blow torch to remove rusty nuts and bolts?
On the farm I'd use the oxy acetylene bottles for big stuff but I haven't got this luxury at home. I needed it to get the front axle swivel bolts out as they are locktited in and I sheared one off as a result. I've got the other side to do this weekend and want to make an easier job of it.
Are plumbers blowtorches any good or are they just not hot enough? It's only needed a few times a year so I don't want anything that expensive.
Are there any other ways of melting loctite to remove bolts easier?
Paul 2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
Post #743657 3rd Dec 2018 9:11am
landy andy
That will do the job. I’ve used it many times for the purpose.
Post #743660 3rd Dec 2018 9:22am
These also work well but are a more expensive solution:
https://www.sykes-pickavant.com/products/w...ating/1802
Post #743664 3rd Dec 2018 9:59am
hank
Cheap propane torches aren't hot enough. MAP gas works a treat!
Interesting you're having trouble with swivel bolts though, mine flew out
Post #743665 3rd Dec 2018 10:02am
You could always go down the oxy-propane route at home. For some reason it scares the neighbours (and insurers) less than oxy-acetylene, plus it can be moved more safely.
Post #743680 3rd Dec 2018 11:10am
williamthedog
Also give the bolt heads a good whack with a hammer to break the loctite seal. Thumbs Up
Post #743693 3rd Dec 2018 11:42am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Sometimes it doesn't take that much heat, ive even nicked the wifes "creme Brule"! mini blow torches from the kitchen, she wasnt happy but the nut came off!
A plumbers one would be ideal, also get one of those plumbers fire proof mats to place around it helps alot if there is rubber/paint nearby
C
Post #743697 3rd Dec 2018 12:30pm
jst
Re: Removing stubborn nuts with heat
Paullr90 wrote:
Hi guys,
Paul
that will work fine on LR sized bolts. not so for argi stuff! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #743714 3rd Dec 2018 2:18pm
Paullr90
Thanks for the advice guys, I'll get one bought. Good call on the heat mat to stop everything nearby getting toasted.
The swivel I did last weekend was definitely due a change after 160,000 miles -
 2003 Td5 90XS
Post #743776 3rd Dec 2018 6:23pm
Snowy90
Plus they are great for getting the woodburner going nice and quick! Beats a match Rolling with laughter
Post #743780 3rd Dec 2018 6:29pm
