Home > Technical > Rusty Sump
jst
Rusty Sump
Anyone have any problems with rusty engine sumps? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225345 8th Apr 2013 7:26am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225348 8th Apr 2013 7:41am
K9F
No as I had mine waxoyled as soon as was convenient. Quick wire brush, coating of Fertan and a little waxoyl and forget it!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #225352 8th Apr 2013 7:51am
jst
if its just external i will do exactly that. but looking at it, its not on a leading edge i was wondering if it was a material imperfection? anyone with the knowledge to know on here? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225356 8th Apr 2013 8:00am
jst
Thumbs Up
you waxoyled the sump? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225357 8th Apr 2013 8:00am
Navigator
I'm sure there will be a front crankshaft oil seal leak along shortly to take care of that.
Post #225367 8th Apr 2013 9:10am
jst
more than likely, although i wasnt aware front cranks were prone on these. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225368 8th Apr 2013 9:12am
Td5.... alloy sump Thumbs Up
Post #225369 8th Apr 2013 9:37am
mikeh501
my landie has a built in oil mist which conveniently stops rust on the sump Mr. Green
Post #225370 8th Apr 2013 9:47am
JWL
There's a trick Land Rover are missing, if they could design a gearbox component towards the rear of the vehicle with LR's history of leaking then even the X-member would get a constant rust preventative treatment every time it was driven Whistle
Post #225393 8th Apr 2013 11:53am
jst
new sump on it now and oil leak to side sorted along with mudflaps and headlight surrounds. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #230638 26th Apr 2013 10:02am
MartinK
Sounds like a warranty-job. No doubt you'll have had a free oil change as well Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #230640 26th Apr 2013 10:11am
chris guala
Switzerland 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Hi all,
Yes, I have an issue of sump corrosion.
This week a did a appointment with the dealer to check the Defender as the warranty expires by mid of December 2018.
By surprise the oil sump has two severe rust spots which could be easy pushed in by a finger….!!
(See attached photos)
Its a Defender Heritage 110 which 67`000 km on the clock.
The reason for that issue is unknown.
Post #742978 29th Nov 2018 5:04pm
I've had mine replaced for new this year, the new type.
My old one was fine but seal started to go.
I also had it Dinitrolled originally, I see on the Dinitrol pages / cans it says not to use it on sump pans etc as I would assume due to flammability if not fully gassed off.
What have others done with theirs? I see Waxoyl mentioned above which is similar.
Has anyone else used a rust proofing agent on theirs? _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #742998 29th Nov 2018 6:50pm
ericvv
My new sump is Dinitrolled. (a new one because that was the only way to recover the broken off oil gauge tip)
The original sump was Dinitrolled too, and both cases the truck did not go up in flames as you seem to say could happen.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #743018 29th Nov 2018 8:42pm
