![]() | Home > Technical > Rusty Sump |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
![]() ![]() James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
No as I had mine waxoyled as soon as was convenient. Quick wire brush, coating of Fertan and a little waxoyl and forget it!
![]() Treat every day as if it is your last....one day you will be right!! |
if its just external i will do exactly that. but looking at it, its not on a leading edge i was wondering if it was a material imperfection? anyone with the knowledge to know on here? Cheers
you waxoyled the sump? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Navigator Member Since: 05 Dec 2012 Location: here Posts: 7 ![]() |
I'm sure there will be a front crankshaft oil seal leak along shortly to take care of that.
more than likely, although i wasnt aware front cranks were prone on these. Cheers
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
Td5.... alloy sump
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
my landie has a built in oil mist which conveniently stops rust on the sump
There's a trick Land Rover are missing, if they could design a gearbox component towards the rear of the vehicle with LR's history of leaking then even the X-member would get a constant rust preventative treatment every time it was driven
new sump on it now and oil leak to side sorted along with mudflaps and headlight surrounds. Cheers
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
Sounds like a warranty-job. No doubt you'll have had a free oil change as well ![]() |
chris guala Member Since: 11 Jan 2016 Location: 4525 Balm b. Günsberg Posts: 3 ![]() ![]() ![]() |
Hi all,
Yes, I have an issue of sump corrosion. This week a did a appointment with the dealer to check the Defender as the warranty expires by mid of December 2018. By surprise the oil sump has two severe rust spots which could be easy pushed in by a finger….!! (See attached photos) Its a Defender Heritage 110 which 67`000 km on the clock. The reason for that issue is unknown. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
I've had mine replaced for new this year, the new type.
My old one was fine but seal started to go. I also had it Dinitrolled originally, I see on the Dinitrol pages / cans it says not to use it on sump pans etc as I would assume due to flammability if not fully gassed off. What have others done with theirs? I see Waxoyl mentioned above which is similar. Has anyone else used a rust proofing agent on theirs? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ Last edited by custom90 on 30th Nov 2018 6:10pm. Edited 1 time in total |
My new sump is Dinitrolled. (a new one because that was the only way to recover the broken off oil gauge tip)
The original sump was Dinitrolled too, and both cases the truck did not go up in flames as you seem to say could happen. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
