![]() | Home > Puma (Tdci) > Clutch lifespan |
| WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
One chap on FB lost his at 6000kms. Another at 140000kms. I’m on 47000kms and its rattles to hell and getting worse so i’m changing mine as soon as the roof on my garage is finished. Moral is you can never tell but now you’ve thought about it you’ve jinxed it too!
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18046
If it's original then I'd change it, and check the output adaptor shaft coupling at the same time. Clutches are better now than in the early days but '09 still wasn't great. My '07 was I think on clutch number 3 by 37k miles.
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
I'd wouldn't think about it. just do it.
no way from what I know would I risk it and as above check / change adapter shaft while in there. Last edited by Caterham on 19th Nov 2018 8:35pm. Edited 1 time in total |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8488
Does it rattle, engine running, neutral, feet off pedals? Cheers
| Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565
Mine does...............
Mine's just under 38k on the original and has rattled for ages (release springs loose I guess). It has a JLR extended warranty. Do you reckon that it would be put down to 'wear and tear'? |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
check this: https://www.defender2.net/forum/topic12243...lutch+poll
it was a poll on when clutches need replaced. I'm on ~40k miles and still original... Appears some people are lucky and clutch lasts for years and years, some others fail early...is it russian roulette, or is it down to the way they are used??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1406
No - which worries me..... Euro-Leafing to infinity and beyond..... |
If it's not rattling then I wouldn't worry Cheers
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Mine was fine until 40k miles. Now I’m on 41.5k and sounds like a steam train is in my gearbox!!
Changing clutch and adaptor shaft this weekend!! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Well my motor was in for a service and MOT at the local Indie today - sadly they showed me a video detailing rust stains around the transfer case......
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Mine's a 2011. Rattled terribly when I bought it at 13k miles so had a new clutch put in.
It's now done 67k miles and I'm still on that clutch and it's not rattling. |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Mines a 2011 too, and was also rattling at around 13k, now on 26k and still rattling.
| RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 695
Mines on 96k miles and it still perfect.
Don’t fiddle with things that ain’t broke 130 Puma HCPU with an Artica 240LR Demountable Camper |
Rust stains most likely from the adaptor shaft...
Click image to enlarge Click image to enlarge Obviously fitted dry from the factory. Next to my new one with the correct grease applied. Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| All times are GMT |
