Home > Puma (Tdci) > Clutch lifespan
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Clutch lifespan
My Puma is a 2009 2.4 model with 37,000 on the clock. I am toying with the idea of a Morocco trip next year, and wonder if I should think about swapping the clutch before I go - I seem to remember a spate of stories about them failing early in their life a while ago. Euro-Leafing to infinity and beyond.....
Post #740327 13th Nov 2018 7:37pm
WindyJ
One chap on FB lost his at 6000kms. Another at 140000kms. I’m on 47000kms and its rattles to hell and getting worse so i’m changing mine as soon as the roof on my garage is finished. Moral is you can never tell but now you’ve thought about it you’ve jinxed it too!
Post #740329 13th Nov 2018 7:41pm
If it's original then I'd change it, and check the output adaptor shaft coupling at the same time. Clutches are better now than in the early days but '09 still wasn't great. My '07 was I think on clutch number 3 by 37k miles.
Post #740332 13th Nov 2018 7:52pm
Caterham
I'd wouldn't think about it. just do it.
no way from what I know would I risk it and as above check / change adapter shaft while in there.
Thumbs Up
Post #740341 13th Nov 2018 8:10pm
jst
Does it rattle, engine running, neutral, feet off pedals? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740353 13th Nov 2018 8:50pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine does............... Shocked
Mine's just under 38k on the original and has rattled for ages (release springs loose I guess).
It has a JLR extended warranty. Do you reckon that it would be put down to 'wear and tear'?
Post #740444 14th Nov 2018 8:47am
MartinK
check this: https://www.defender2.net/forum/topic12243...lutch+poll
it was a poll on when clutches need replaced.
I'm on ~40k miles and still original...
Appears some people are lucky and clutch lasts for years and years, some others fail early...is it russian roulette, or is it down to the way they are used??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #740447 14th Nov 2018 9:21am
strang
No - which worries me..... Euro-Leafing to infinity and beyond.....
Post #740535 14th Nov 2018 7:27pm
jst
If it's not rattling then I wouldn't worry Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740541 14th Nov 2018 8:03pm
Roy5695
Mine was fine until 40k miles. Now I’m on 41.5k and sounds like a steam train is in my gearbox!!
Changing clutch and adaptor shaft this weekend!! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #740547 14th Nov 2018 8:32pm
strang
Well my motor was in for a service and MOT at the local Indie today - sadly they showed me a video detailing rust stains around the transfer case...... Big Cry Euro-Leafing to infinity and beyond.....
Post #741285 19th Nov 2018 7:48pm
Cupboard
Mine's a 2011. Rattled terribly when I bought it at 13k miles so had a new clutch put in.
It's now done 67k miles and I'm still on that clutch and it's not rattling.
Post #741287 19th Nov 2018 8:14pm
DAZ110
Mines a 2011 too, and was also rattling at around 13k, now on 26k and still rattling. Embarassed
Post #741290 19th Nov 2018 8:30pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mines on 96k miles and it still perfect.
Don’t fiddle with things that ain’t broke 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #741292 19th Nov 2018 8:37pm
Roy5695
Rust stains most likely from the adaptor shaft...
Obviously fitted dry from the factory. Next to my new one with the correct grease applied.
Instagram - @r22oyp
Roy
Post #741375 19th Nov 2018 11:59pm
