![]() | Home > Maintenance & Modifications > Dark times ahead - Scene lighting |
The modified mirror arm is GENIUS! ![]() ![]() |
Does the shape improve the amount of light? ![]() ![]() |
Love it Steve. Another top mounting solution. How did you route the cables?? Actually, has everyone permanently routed the cables or devised a non-invasive/damaging method of cabling? With the roof rack I am contemplating a bulkhead style plug so I can remove the rack when not needed. Still pondering on whether this is actually needed. |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
Geobloke,
"How did you route the cables?? Actually, has everyone permanently routed the cables or devised a non-invasive/damaging method of cabling? With the roof rack I am contemplating a bulkhead style plug so I can remove the rack when not needed. Still pondering on whether this is actually needed." I have the same rack lighting project ongoing and pondering the very same question. Therefore watching your thread with interest. As for bulkhead connectors, so far, these seem interesting.... https://www.bulgin.com/products/circular-power-connectors.html But there may be other options out there? I'll post up any more info i find. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Cheers! I used proper plated brass cable glands; one either side of the rear window. The height they are at means the cables are hidden totally behind the headlining. I used a 2core cable for each light so it has a round cross section and seals properly into the gland. I just fitted superseal connectors to the lights. I wouldnt even have bothered with these of the lights hadnt already got short cables moulded into the housing. I cant see the need in connectors if you dont plan on removing them often. ![]() Click image to enlarge 02' 110 TD5 Double Cab Rebuild Thread |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Just to post something different for the sake of it..
I have a scenelight mounted where the rear wash/wipe was. Just for symmetry. I'll probably put the wash/wipe back in due course. But if I need light around the sides, then I'll use this. The light itself has changed to an LED one, but this gives the idea - just a cheapy worklight and cheapy clamp which goes onto the gutter wherever it's needed. https://www.defender2.net/gallery/displayi...amp;pos=15 Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Cheap, eBay special, LED flood lights, although it appears that those specific ones are out of stock at the moment: https://www.ebay.co.uk/itm/18W-cree-LED-Wo...pCJSZZd8tw Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
In a different note and a bit of a thread hijack, what colour are your headlight surrounds OP, and is your grille the same colour? It’s a great contrast against the blue and I want to do the same!
They look like standard XS ones, which are Brunel grey. Darren
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
If you were looking for something solely for reversing then twin reversing lights do make a difference. I noticed a big improvement by fitting a second one to my defender
![]() ![]() Click image to enlarge Obviously no good as a work light but a definite improvement for reversing ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thanks. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I have contemplated doing the same on the current 110 for a couple of years as I did on the 300tdi but for some reason I cannot convince myself that there is enough room to get the three lights in a line without having move the existing two and drill more holes. How did you manage to fit them? Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
There is definitely room on a Td5. As the 300 has rectangular lights they may be mounted slightly further inboard from the factory.
I just measured a million times and drilled once ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
![]() Click image to enlarge As you can see the hinge side is the tightest. I did this side first and then transferred the measurements to the other side ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
