![]() | Home > Maintenance & Modifications > Dark times ahead - Scene lighting |
Morning folks.
So, we are now heading with great haste in to the depths of Winters dark mornings and darker evenings. This morning I was once again reminded that the single reversing light on the Defender is pitiful, even if it is the up rated LED version. I am looking for inspiration... At present I am thinking of mounting a combination of lights around the roof rack of Miffy; flood/work light style on the rear and smaller scene-style lights on the flanks so we can see what we are stepping on during those early morning dog walks. What have you done to boost your vehicles rear lighting or even "all round" scene lighting? This is Miffy; ![]() Click image to enlarge ![]() Click image to enlarge |
One or a few Labcraft S17 Scenelight. Below an entire thread about its virtues.
Eric http://www.defender2.net/forum/topic32834....scenelight You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Good grief... Six pages of virtues... ![]() ![]() |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
I've fitted a pair of 18w LED flood lights, which have been positioned so that they don't project above the roof (not an issue if fitting to a rack) and are not obscured by the rear door being opened.
![]() Click image to enlarge I was originally going to go for a Scenelight positioned centrally above the door but it interfered with plans that I have for a reversing camera. Also, two lights spaced as these are should reduce shadows and give a more even light over a wider area. That's the theory, anyway. They work really well, although I’ve aimed them down slightly since I took this picture: ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
I'd suggest Rigid 2x1 Scene lights to the rear or 2x2 if you want traditional worklight style. Lifetime warranty (2 year on powdercoat) and they are very small but bright.
I'm also putting Rigid Ignite units down each side under the rack for some side illumination. https://www.rigidindustries.com/ignite-backup-kit-bu-ignite.html https://www.rigidindustries.com/1x2-65deg-...86610.html Other options (that I don't normally sell) are Labcraft SI series scene lights, probably the most common ones out there but I think they are fairly bulky for the light output. Give me a shout at McKenzies on 01228 528 218 and I'll sort out a decent Defender2 discount for you. North Cumbria Search and Rescue - Team Leader |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
I doubled up the reverse light & mounted 2 lights on the roof, switched at the dash
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Douglas Adams 2012 2.2 Puma |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
I have one round high level light, comes on with the reverse light, but also can come on with a dash mounted switch.
Old picture, its now round.
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
It is marginally better than the standard light.
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
12 inch 72W LED light bar mounted centrally over door.
A combination of flood and spot LED's ........... all the rear light you'll need and only £25 - £30 on e-Bay ![]() If you really want to overdo it, a 20 inch 120W version is only a few quid more ![]() |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2239 ![]() ![]() ![]() |
I made some brackets for side lights on my DCPU. Also cheap chinese LED from ebay but perfect for this use.
![]() Click image to enlarge Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks LRS. Rear view camera aside (that's another topic I will pick your brains on I expect), what make are those lamps? |
Love it, super "ol Skool"... ![]() |
Are those Rigid Ind lights or the similar but NOT Rigid Ind lights? |
